NTP Synchronize problem
goutam_04
I have configured NTP server properly and it was working fine.  But due to some reason I had to configure "Ip routing" on switch.  After that I have been facing this problem. i.e. NTP is not synchronized.
Again when I remove "Ip routing" command then its working fine.  Could any one can give me some idea why its happening.
Goutam
15 Replies 15
So did you check to see if you are using a default gateway command or a default static route?  Have no idea why they would tell you changing it from a layer 2 switch to a layer 3 functional switch , that should make no difference of why it crashed , we have hundreds of 3560's setup as L2 only..  I would post your config on the switch you are talking about.
