04-29-2019 09:54 AM
IOS XE on Cat 4500-X supports 256 port channels with VSS. Can someone tell me if it is the same on the Cat 9Ks? or, how many port channels does IOS XE support in the Cat 9Ks?
Thanx
Solved! Go to Solution.
04-29-2019 11:32 AM
04-29-2019 11:32 AM
On the 9300 series, it is 128.
1-128
04-29-2019 02:04 PM
Thechannel-groupcommandbinds the physicalport and the port-channelinterfacetogether. EachEtherChannelhasaport-channellogicalinterfacenumberedfrom1to128.
04-29-2019 02:39 PM
I saw that documentation also. I was hoping that the 9Ks would have the same "multiplying" behavior the 4500-Xs do -- 64 port channels on a single switch, but 256 in a VSS pair (or maybe I am incorrect on that?).
04-29-2019 03:17 PM - edited 04-29-2019 03:18 PM
Cat 9K more of StackWise Virtual ( traditional 6K is VSS ) I belive still StackWise virtual stand same as 128 max.
04-29-2019 05:10 PM
That is correct. For the 4500x VSS, the total number is 256
<1-256> Port-channel interface number
