odd pinging problem
harrisgirls
Level 3
Level 3
Hello Guys,
I know this is HP related but the forums over there are dire!..............Right I have just received 8x HP  2530-48G-PoE+ Switch (J9772A), applied a very basic config to these and  tagged the port on the core (5406zl), now when its all connected i get  some very strange pinging responces, :
Me pinging from 2530::
2530 GUI:
Me pinging 2530 from laptop\server:
me ping core via 2530...............:
show cpu on 2530:
NOTE:
I also have 11x 2510G switches and every one of them works fine, i do not see this issue.....like with the 2530, same config etc,
I have tried 4x 2530 switches and they ALL do the same.
I have done the following:
I've updated the firmware on all of them - didnt make any difference
i've booted into the secondary image - didnt make any difference
Wiped them clean - - didnt make any difference
Updated the software on the 5406zl to the latest
Used difference cables (the 2530 is uplinked via a copper cables)
Ran the 2530 ON ITS ON with its own IP with a basic config and the pings are still all over the place when running on its own!
Ran the 2530 totally standalone!........with just an IP assigned and still does the same.
I cannot see anything in show logging.
No errors
Any ideas?
I've attached the show tech all log.....
jimmysands73_2
Level 9
Level 9
You never said what the problem is.  Are we to assume your concerned about the ping times?
This morning on our network, pinging from one school to a diff school, with no traffic (sat morning):
* 0572-RTR-01:2 # ping con 10.3.4.6
Ping(ICMP) 10.3.4.6: 8 data bytes, interval= 1.
16 bytes from 10.3.4.6: icmp_seq=0 ttl=126 time=0 ms
16 bytes from 10.3.4.6: icmp_seq=1 ttl=126 time=0 ms
16 bytes from 10.3.4.6: icmp_seq=2 ttl=126 time=10 ms
16 bytes from 10.3.4.6: icmp_seq=3 ttl=126 time=0 ms
16 bytes from 10.3.4.6: icmp_seq=4 ttl=126 time=0 ms
16 bytes from 10.3.4.6: icmp_seq=5 ttl=126 time=10 ms
16 bytes from 10.3.4.6: icmp_seq=6 ttl=126 time=0 ms
16 bytes from 10.3.4.6: icmp_seq=7 ttl=126 time=0 ms
16 bytes from 10.3.4.6: icmp_seq=8 ttl=126 time=0 ms
16 bytes from 10.3.4.6: icmp_seq=9 ttl=126 time=0 ms
16 bytes from 10.3.4.6: icmp_seq=10 ttl=126 time=0 ms
16 bytes from 10.3.4.6: icmp_seq=11 ttl=126 time=50 ms
16 bytes from 10.3.4.6: icmp_seq=12 ttl=126 time=0 ms
16 bytes from 10.3.4.6: icmp_seq=13 ttl=126 time=0 ms
16 bytes from 10.3.4.6: icmp_seq=14 ttl=126 time=10 ms
16 bytes from 10.3.4.6: icmp_seq=15 ttl=126 time=0 ms
16 bytes from 10.3.4.6: icmp_seq=16 ttl=126 time=0 ms
The issue is the ping reponces all over the place on this model switch
