option#43 for mitel phones on cisco asa 5505
kashif.ahmad837
Hi all,
I have configured option #43 for mitel phone on cisco asa. but the phones are not getting the ip address from the dhcp.
this is the command on the asa
"dhcpd option 43 ascii id:ipphone.mitel.com;sw_tftp=64.28.118.9;call_srv=64.28.118.9;l2p=6v6s6;dscp=46v46v26"
this is the debug output on asa "debug dhcpd packet"
DHCPD: Total # of raw options copied to outgoing DHCP message is 0.
DHCPD: broadcasting BOOTREPLY to client 0800.0faf.b283.
DHCPD: Server msg received, fip=ANY, fport=0 on inside interface
DHCPD: DHCPDISCOVER received from client 0108.000f.afb0.a5 on interface inside.
DHCPD: Sending DHCPOFFER to client 0108.000f.afb0.a5 (10.133.48.40).
DHCPD: broadcasting BOOTREPLY to client 0800.0faf.b0a5.
DHCPD: DHCPDISCOVER received from client 0108.000f.aa58.22 on interface inside.
DHCPD: Sending DHCPOFFER to client 0108.000f.aa58.22 (10.133.48.41).
DHCPD: broadcasting BOOTREPLY to client 0800.0faa.5822.
DHCPD: DHCPDISCOVER received from client 0108.000f.afb2.83 on interface inside.
DHCPD: Sending DHCPOFFER to client 0108.000f.afb2.83 (10.133.48.32).
DHCPD: DHCPDISCOVER received from client 0108.000f.aa3c.65 on interface inside.
DHCPD: Sending DHCPOFFER to client 0108.000f.aa3c.65 (10.133.48.30).
DHCPD: broadcasting BOOTREPLY to client 0800.0faa.3c65.
thanks and regards
6 Replies 6
as far as I remember, you need to configure option 60 (vendor-ID) as well on the ASA...
I did ant it is still not working.
can you add the Vlan identifier to your command (x is the Vlan number in which your phones are configured:
"dhcpd option 43 ascii id:ipphone.mitel.com;sw_tftp=64.28.118.9;call_srv=64.28.118.9;vlan=x;l2p=6v6s6;dscp=46v46v26"
I have tried it, still not working. I get the same msgs as before
make sure the following ports are open on your ASA:
UDP: 69, 20001, 6004-6261, 50098-50508
TCP: 3998-3999, 6800-6802
Can you post the config of your ASA ?
Everything was good.
Only this command was missing
Switchport voice vlan dot1p
it is working now
Thank you guys for replying.
