OSPF authentication
chris_moyzan
Community Member
Hi guys. I`m being tasked to add OSPF authentication to all our devices that use OSPF. I did some research and I know how to do it. The thing is, I'm not sure how I could do it in a timely manner... Also, how can I tell which interface is in which OSPF process? When I do a show ip ospf, it lists the processes and tells me how many interfaces are in the process but doesn't tell me which ones.
Is there a way to enter the md5 password at the area level instead of at the interface level? That would be much quicker and easier for me.
Yes, on multilayer switches it is possible to use the "interface range" command similarly to this:
conf t
interface range Gig0/1 - 30
no switchport
ip ospf message-key 1 md5 xxxx
Cheers:
Istvan
6 Replies 6
Istvan_Rabai
Level 11
Level 11
Hi Chris,
Use the "show ip ospf interface serial1/0" type command to see which area the interface is attached to.
If you use the "show ip ospf interface", it will list all interfaces configured for OSPF.
I know only of interface level authentication as to the configuration of authentication keys.
Cheers:
Istvan
Thanks for your reply, Istvan, although it's a bit of a letdown since I have lots of interface to configure 😞 On our main switch I have 3 processes with about 30 interfaces. Is it possible to enter the "Ip ospf message-key 1 md5 password on an interface range?
conf t
no switchport
Cheers:
Istvan
Ok, thanks, I'll do more testing.
You may also want to remember to be careful when you apply the Md5 key: dont add any extra spaces on one side....sometimes that happens when you use Notepad to make sweeping config changes.
Victor
Thanks, Victor, I will check to make sure there aren't any problems with the key. I did some tests and it seems I can set a key for an interface even though authentication is not set in the area. This simplifies my task since I'll just apply the command to a range of interfaces.
