OSPF configuration on interface or under 'router ospf xx'
branfarm1
Level 4
Level 4
Hi there,
What's the functional difference between configuring ospf at the interface level, such as:
interface GigabitEthernet6/1
no switchport
ip address 10.5.10.1 255.255.255.252
ip ospf 100 area 1
versus:
router ospf 100
network 10.5.10.1 0.0.0.0 area 1
Thanks in advance,
Brandon
Edison Ortiz
No functional differences. If you have a lot of interfaces and they can be grouped within a summarized network entry, having the router ospf process configured, requires less typing.
Edison Ortiz
Thanks Edison!
esomarriba
Level 5
Level 5
It's another way of doing things. I like the old style format, going under router ospf xxx (like old-shool) , I like to make sure that only the interface that I want participate on the ospf process, so I combine it with passive-inter default and enable only the interface I want to enable for ospf with pass-inter inter gigx/y.
That makes more sense if you need to debug ip os adj if you are having problems with peering, etc...
HTH,
Elyinn.-
