OSPF configuration
jonk34567
Level 6
Level 6
i need to configure ospf in interface mode. may i know the command for each router ( R1, R2 and R3 )
Deepak Kumar
OSPF configuration on an interface command is IP OSPF <Process ID> area <Area Number>
Router(config)# interface Ethernet 0/0/0
Router(config-if)# ip address 172.16.1.2 255.255.255.0
Router(config-if)# ip ospf 1 area 0
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Muhammad Uzair
Level 4
Level 4
The command to run OSPF in an interface mode is "IP ospf (process ID) area (ID) "
For more you can go through the below document.
https://www.cisco.com/c/en/us/td/docs/ios/12_0s/feature/guide/ospfarea.html
Thank you.
Kindest regards,
Uzzi
Kindest regards,
Uzair
CCENT, CCNA (R&S), CCNP (R&S).
Deepak Kumar
Deepak Kumar
Deepak Kumar,
