OSPF dies when apply ACL
nawas
Level 4
Level 4
I'm using the following ACL on my distribution router which connects to core and as soon as as i apply inboud or outboud the ospf dies, i see the log dead time expired. Do I need to allow anything in the ACL for OSPF to work? Please advice
ip access-list extended my-filter-inbound
permit ip 10.8.0.0 0.0.255.255 10.13.0.0 0.0.255.255
permit ip 10.1.31.0 0.0.0.255 10.13.0.0 0.0.255.255
permit ip 10.1.32.0 0.0.0.255 10.13.0.0 0.0.255.255
permit ip 10.5.30.0 0.0.0.255 10.13.0.0 0.0.255.255
permit ip 10.7.149.0 0.0.0.255 10.13.0.0 0.0.255.255
interface vlan 320
ip access-group my-filter-inbound in
ip access-group my-filter-inbound out
7 Replies 7
Edison Ortiz
OSPF is its own protocol, so you need something like:
permit ospf [source] [destination]
Add 'permit ospf any any' to the existing ACL to allow OSPF packets.
Sundar
lamav
Level 8
Level 8
I imagine that you are using a point-to-point OSPF network type, since you are talking about the links between your core and distribution layer switches in the data Center. Recall that with OSPF point-to-point networks, LSAs are multicast to on 224.0.0.5, the AllSPFRouters address.
try allowing such traffic as part of the access list and get back to us with the results.
I agree with Edison and Sundar and it would be better to allow all ospf packets
Have a look at this link. though it talks about vulnerabilities in ospf it would give an idea of how to configure an access-list that would permit ospf packets and maintain adjacency
http://www.cisco.com/en/US/products/products_security_response09186a008014ac50.html
Narayan
please rate all useful posts
Royal:
I was giving the questioner a conceptual solution and approach, not the actual config lines. The point I was making was that OSPF traffic should be permitted and why it is that his access list fails ot permit it.
Thanks everyone for their valuable input. I tired both solution, ie permit ospf any any and permit ospf multicast packet and both have worked flawlessly. At this time I'm going to use permit ospf any any (for simplicity).
Glad ot hear it, Nawas!
