Other VSS notice except the compatibility between CFC and DFC doughter card.
mhiyoshi
Level 3
Level 3
Hello
I have already understood the following notice for using VSS function with 6700 series modules.
However I appreciate if there is any other noice, please let me know.
For example there is the compatibility HW revision issue between the 6700 line card and CFC or DFC and so on.
[Virtual Switching System (VSS) Q&A]
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/prod_qas0900aecd806ed74b.html
All 6700 series modules with Centralized Forwarding card (CFC)
All 6700 series modules with Distributed Forwarding Card (DFC) 3C or DFC3CXL
Best Regards,
Masanobu Hiyoshi
Reza Sharifi
Table-1 in the link you posted provides all the requirement and restrictions.  As long as you follow this page, you should be fine.  Remember, these restrictions are for Sup-720-VS, if you are using Sup-2T, you would need to look at this page:
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps11878/qa_c67-648478.html
