Over Subscription Ratio
Alexander1023
Going from Access to Distribution layer Cisco's recommendation is a 20:1 subscription ratio. Is it possible to dynamically throttle switch ports (prevent devices from connecting at 1000M) once that uplink threshold is met?
-Alex
some sort of QoS/traffic shaping should work. What platform/models are your switches ?
Joseph W. Doherty
It might be possible using an EEM script, but realize the 20:1 ratio is a very. very rough rule-of-thumb, and also understand uplink bandwidth management might be better done using QoS.
Scott Hodgdon
Alexander,
Is it possible ? Yes. You could use scripting (depending on which switch / IOS you are using) and EEM to monitor total uplink bandwidth every so often and then execute a command to set all ports to 100-full if the bandwidth exceeds a certain amount. However, you would also then want to reset the ports to "auto" (to get back to 1000-full) if the bandwidth is lower than 20:1, right ? Resetting the port speed takes down the connection to the client so that negotiation can occur. What if the bandwidth is fluctuating to barely above and then barely below 20:1 ? The system would be resetting port speeds very frequently, causing a very negative user experience due to the ports flapping. So while possible, it would not be recommended at all. I think you would be better off to identify your power users that might actually need the 1000-full setting, leave their ports at "auto" and then set the rest of the ports to 100-full for the rest of your users.
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking Group
