Packet drop between FWSM and 6500
I have packet drop issue between FWSM and 6500, I believe. Packets transiting through a particular vlan are intermittently being dropped. I have taken packet capture on FWSM and it shows that some of the echo requests to a servers does not get response back. At the same time packet capute was taked on the NIC of server and it shows no problems, all echo requests are being replied back properly. So this concludes that the unreplied echo request never reached server.
'sh np blocks' has all 0's in threshhold values
Here is the output of the etherchannel beween FWSM and 6500 (of course created automatically)
DR-KMPLF#sh int po 578 counters etherchannel
Port                InOctets   InUcastPkts   InMcastPkts   InBcastPkts
Po578         30043323428709   42076894290     257207347       4018763
Gi1/2/1                  176             1             0             1
Gi1/2/2                  176             1             0             1
Gi1/2/3               850300          7625             0           577
Gi1/2/4                  176             1             0             1
Gi1/2/5                  176             1             0             1
Gi1/2/6            597674383       3552695             0            67
Port               OutOctets  OutUcastPkts  OutMcastPkts  OutBcastPkts
Po578         29904465074209   41224244267     388975402       2251786
Gi1/2/1           7190383150      27868993      21660120         39163
Gi1/2/2           1062054141       5637578        876883        644905
Gi1/2/3            738425356          2511       2088658          5327
Gi1/2/4            408526405          5787       3371754          4085
Gi1/2/5            649356137          4973       4267284         14212
Gi1/2/6            351483674        182554       1413610         67163
This is a VSS setup with latest software on FWSM (4.1[6]) and SUP (12.2(33)SXI3).
Experts, please advise
Saif
Richard Michael
Hello saifuddin,
Can you please give me more details on your problem,
How is your switch MAC aging timer and ARP timers are configured?
Is this issue happening only for one server or with multiple servers/hosts?
no mac-add aging-type routed-mac - Do you see this command in your switch?
Do you have MAC-address table Sync command enabled in your 6500(If you are using DFC line cards)?
Can you please share the Show module output from the switch, Need to know if you have a DFC linecards.
Share the output of sh mac-add all detail
Ricky Micky
Hi Richard,
All the timers for MAC ageing are at default, we didn't change any of those.
The issue is visible on a few particular servers in a vlan, We dint check if the issue exists with other vlan as well.
'no mac-add aging-type routed-mac' command does NOT exist in the configuration.
------------------ show module switch all ------------------
Switch Number:     1   Role:   Virtual Switch Active
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL142XXXXX
  2    6  Firewall Module                        WS-SVC-FWM-1       SAL142XXXXX
  3   16  CEF720 16 port 10GE                    WS-X6716-10GE      SAL142XXXXX
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL142XXXXX
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  c84c.75b8.0210 to c84c.75b8.023f   3.4   12.2(18r)S1  12.2(33)SXI3 Ok
  2  5475.d062.57a0 to 5475.d062.57a7   4.5   7.2(1)       4.1(6)       Ok
  3  8843.e1d1.64c0 to 8843.e1d1.64cf   1.1   12.2(18r)S1  12.2(33)SXI3 Ok
  5  0025.84bf.e108 to 0025.84bf.e10f   3.2   8.5(4)       12.2(33)SXI3 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       SAL142XXXXX  4.1    Ok
  3  Distributed Forwarding Card WS-F6700-DFC3C     SAL142XXXXX  1.4    Ok
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAL142XXXXX  1.1    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL142XXXXX  5.0    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  5  Pass
Switch Number:     2   Role:  Virtual Switch Standby
  5    5  Supervisor Engine 720 10GE (Hot)       VS-S720-10G        SAL142XXXXX
  1  c84c.75b8.0c90 to c84c.75b8.0cbf   3.4   12.2(18r)S1  12.2(33)SXI3 Ok
  2  5475.d062.55e0 to 5475.d062.55e7   4.5   7.2(1)       4.1(6)       Ok
  3  8843.e1d1.5a70 to 8843.e1d1.5a7f   1.1   12.2(18r)S1  12.2(33)SXI3 Ok
  5  c47d.4ffd.e360 to c47d.4ffd.e367   3.2   8.5(4)       12.2(33)SXI3 Ok
  1  Pass
  2  Pass
  3  Pass
  5  Pass
------------------ show mac-address-table ------------------
Legend: * - primary entry
        age - seconds since last seen
        n/a - not available
  vlan   mac address     type    learn     age              ports
    14  e41f.1365.0b40   dynamic  Yes          0   Po104
*  101  5475.d0e5.4900   dynamic  Yes          0   Po594
*  151  3333.0001.0002    static  Yes          -
*  ---  0000.0000.0000    static  No           -   Router
    13  e41f.1364.d310   dynamic  Yes          0   Po103
    13  e41f.1365.1304   dynamic  Yes         10   Po101
    13  e41f.1343.c898   dynamic  Yes          0   Po103
*    1  0100.0ccc.cccc    static  No           -   Switch
*    1  c84c.7581.8000    static  No           -   Router
*   19  5475.d0e5.5b80   dynamic  Yes        170   Po594
    13  e41f.1365.13c8   dynamic  Yes         20   Po101
*   16  5475.d0e5.5b80   dynamic  Yes        135   Po594
*    8  c84c.7581.8000    static  No           -   Router
*   14  5475.d0e5.5b80   dynamic  Yes        250   Po594
*   13  5475.d0e5.5b80   dynamic  Yes        130   Po594
*  101  5475.d0e5.5b80   dynamic  Yes          0   Po578
    13  e41f.1365.0d64   dynamic  Yes         15   Po104
    13  e41f.1364.cf10   dynamic  Yes         10   Po102
    12  e41f.1365.0c70   dynamic  Yes          5   Po102
    13  e41f.1365.0404   dynamic  Yes          5   Po103
*  ---  0000.0000.aaaa    static  No           -   Switch
*  ---  c84c.7581.8000    static  No           -   Router
    16  e41f.1365.035c   dynamic  Yes          0   Po101
    13  e41f.1365.047c   dynamic  Yes         20   Po103
*  151  d485.64cc.2b88   dynamic  Yes        160   Gi1/1/5
*  205  c84c.7581.8000    static  No           -   Router
*  151  d485.646b.d3ca   dynamic  Yes          5   Gi1/1/2
*  151  d485.646b.d3c8   dynamic  Yes          0   Gi1/1/4
    14  e41f.1365.04a4   dynamic  Yes         10   Po104
*  151  5475.d0e5.5b80   dynamic  Yes          5   Po594
    13  e41f.1363.a53c   dynamic  Yes         10   Po101
     8  0080.e518.0c54   dynamic  Yes        170   Po101
*    8  3333.0001.0002    static  Yes          -
    14  e41f.1363.fecc   dynamic  Yes         20   Po104
    13  e41f.1361.8c18   dynamic  Yes          0   Po101
    13  e41f.1364.e494   dynamic  Yes         20   Po102
    13  e41f.1364.ea50   dynamic  Yes         10   Po102
   205  0026.9964.2440   dynamic  Yes          0   Po3
*   12  5475.d0e5.5b80   dynamic  Yes         95   Po594
*   15  5475.d0e5.5b80   dynamic  Yes        215   Po594
*    7  c84c.7581.8000    static  No           -   Router
*   19  c84c.7581.8000    static  No           -   Router
Hello saifuddin,
This is too early to predict but i guess you are hitting the bug CSCth04998. If you can try upgrading it to SXI5 or SXJ and let me know if this problem re-appears.
Ricky Micky
*Pls rate useful posts
