Packet Drop
Behnam.Ghasemiyeganeh
Frequent Visitor
Frequent Visitor
Hello
i rebooted a switch. when that comes up again. i only got the port started with packet drop, takes the packets and throws them away. the port is trunk port. i saw the log file there i got the errors with host ..... vlan flapping between the ports.
so I had to configure other ports
we have RSTP
I wanted to ask how can I use the port again.
the port is configured as trunk
balaji.bandi
Can you post the configuration of the device and logs for reference to advise properly
also please post the device model and show version, how this is connected to other device some network toplogy to understnad
post below output from both devices
show inter trunk
show spanning-tree summary
BB
the problem is that the AP is no longer connected to the switch, so everything is fine under the show commands.
I wanted to know if the problem would reoccur, how I could solve it.
Should I delete the MAC address from the corresponding port?
and reset port
until we see some information what we requete, not have any clue what was the issue you had ?
BB
