Packet drops on queue on 6509 even though QOS is disabled
Much apprecited if you can assist with the following
I can see drops on the 6509 Queue for interface gi1/6 , qos is disabled globaly with qos disabled all packets are in one Queue using best effort my question is if I can see drops using the sh queueing int Gi1/6 command  why I am not seeing any drops when I run the Sh int (interface number )  command,  pls help in confirming which one is right and which one is wrong (As always thanks in advance)
I have highlight the important bits in the show command below
#sh queueing interface gi1/6
Interface GigabitEthernet1/6 queueing strategy:  Weighted Round-Robin
  QoS is disabled globally
  Trust state: trust DSCP
  Extend trust state: not trusted [COS = 0]
  Default COS is 0
    Queueing Mode In Tx direction: mode-cos
    Transmit queues [type = 1p3q8t]:
    Queue Id    Scheduling  Num of thresholds
       01         WRR                 08
       02         WRR                 08
       03         WRR                 08
       04         Priority            01
    WRR bandwidth ratios:  100[queue 1]   0[queue 2]   0[queue 3]
    queue-limit ratios:    100[queue 1]   0[queue 2]   0[queue 3]
    queue tail-drop-thresholds
    1     100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    2     100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    3     100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    queue random-detect-min-thresholds
    queue random-detect-max-thresholds
    WRED disabled queues:      1  2  3
    queue thresh cos-map
    1     1      0 1 2 3 4 5 6 7
    1     2
    1     3
    1     4
    1     5
    1     6
    1     7
    1     8
    2     1
    2     2
    2     3
    2     4
    2     5
    2     6
    2     7
    2     8
    3     1
    3     2
    3     3
    3     4
    3     5
    3     6
    3     7
    3     8
    4     1
    Queueing Mode In Rx direction: mode-cos
    Receive queues [type = 1q8t]:
       01         WRR                 08
    1     1      0 1 2 3 4 5 6 7
    1     2
    1     3
    1     4
    1     5
    1     6
    1     7
    1     8
  Packets dropped on Transmit:
    queue     dropped  [cos-map]
    1        999434248  [0 1 2 3 4 5 6 7 ]
    2                0  []
    3                0  []
    4                0  []
  Packets dropped on Receive:
    1                0  [0 1 2 3 4 5 6 7 ]
sh int Gi1/6
GigabitEthernet1/6 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0011.938a.c311 (bia 0011.938a.c311)
  Description: KB-SR2-3750-1
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 47/255, rxload 29/255
  Full-duplex, 1000Mb/s, media type is SX
  input flow-control is off, output flow-control is desired
  Clock mode is auto
  Last input 00:00:14, output 00:00:37, output hang never
  Last clearing of "show interface" counters 25w5d
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 117181000 bits/sec, 12429 packets/sec
  5 minute output rate 186908000 bits/sec, 41943 packets/sec
     334406731490 packets input, 243949476142597 bytes, 0 no buffer
     Received 56321478 broadcasts (46821798 multicast)
     0 watchdog, 0 multicast, 0 pause input
     972231767415 packets output, 819107739728278 bytes, 0 underruns
7 Replies 7
InayathUlla Sharieff
Hi Zeeshan,
Can you please let me know what type of module is this? And can you check the drop on any other interface?
Eg: G1/5-8 and paste the outputs here.
Inayath
Hi Sharief,
MAny Thanks for your response pls find stats below  ( I have highlighted Gi1/5 is seeng an simillar output )
IOS  ===== sup-bootflash:s72033-psv-mz.122-18.SXD3.bin
  1   48  CEF720 48 port 1000mb SFP              WS-X6748-SFP         (module 1)
  2   48  CEF720 48 port 1000mb SFP              WS-X6748-SFP
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-BASE
  6   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP
  7   48  CEF720 48 port 1000mb SFP              WS-X6748-SFP
KB-SR1-6509-1#sh int Gi1/5
GigabitEthernet1/5 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0011.938a.c310 (bia 0011.938a.c310)
     reliability 255/255, txload 27/255, rxload 5/255
  Clock mode is auto
  Last input 00:00:43, output 00:00:44, output hang never
  Last clearing of "show interface" counters 26w0d
  5 minute input rate 19745000 bits/sec, 7084 packets/sec
  5 minute output rate 108463000 bits/sec, 16729 packets/sec
     241773594031 packets input, 136899269013443 bytes, 0 no buffer
     Received 671633855 broadcasts (605934970 multicast)
      579219400946 packets output, 545611531691575 bytes, 0 underruns
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#sh int Gi1/7
GigabitEthernet1/7 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0011.938a.c312 (bia 0011.938a.c312)
  Description: KB-BA-2950-1
  input flow-control is off, output flow-control is on
  Clock mode is auto
  Last input 00:00:24, output 00:00:45, output hang never
Input queue: 0/2000/371/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 5000 bits/sec, 8 packets/sec
  5 minute output rate 74000 bits/sec, 89 packets/sec
     539693149 packets input, 129418363989 bytes, 0 no buffer
     Received 19516879 broadcasts (7454557 multicast)
     371 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
      2835803551 packets output, 753743605221 bytes, 0 underruns
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#sh int Gi1/8
GigabitEthernet1/8 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0011.938a.c313 (bia 0011.938a.c313)
  Description: KB-BB-2950-1
  Clock mode is auto
  Last input 00:00:17, output 00:00:48, output hang never
  Input queue: 0/2000/326/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 36000 bits/sec, 36 packets/sec
  5 minute output rate 225000 bits/sec, 143 packets/sec
     421876077 packets input, 104715544364 bytes, 0 no buffer
     Received 23202949 broadcasts (4202628 multicast)
     326 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
      2953680934 packets output, 585323146311 bytes, 0 underruns
KB-SR1-6509-1#sh queueing interface Gi1/5
Interface GigabitEthernet1/5 queueing strategy:  Weighted Round-Robin
  Default COS is 0
       01         WRR                 08
       02         WRR                 08
       03         WRR                 08
       04         Priority            01
    1     1      0 1 2 3 4 5 6 7
    1     2
    1     3
    1     4
    1     5
    1     6
     1     7
    1     8
    2     1
    2     2
    2     3
    2     4
    2     5
    2     6
    2     7
    2     8
    3     1
    3     2
    3     3
    3     4
    3     5
    3     6
    3     7
    3     8
    4     1
       01         WRR                 08
    1     1      0 1 2 3 4 5 6 7
    1     2
    1     3
    1     4
    1     5
    1     6
    1     7
    1     8
   1       1194074609  [0 1 2 3 4 5 6 7 ]
    2                0  []
    3                0  []
    4                0  []
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#sh queueing interface Gi1/7
Interface GigabitEthernet1/7 queueing strategy:  Weighted Round-Robin
  Default COS is 0
       01         WRR                 08
       02         WRR                 08
       03         WRR                 08
       04         Priority            01
    1     1      0 1 2 3 4 5 6 7
    1     2
    1     3
    1     4
    1     5
    1     6
     1     7
    1     8
    2     1
    2     2
    2     3
    2     4
    2     5
    2     6
    2     7
    2     8
    3     1
    3     2
    3     3
    3     4
    3     5
    3     6
    3     7
    3     8
    4     1
       01         WRR                 08
    1     1      0 1 2 3 4 5 6 7
    1     2
    1     3
    1     4
    1     5
    1     6
    1     7
    1     8
    2                0  []
    3                0  []
    4                0  []
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#
KB-SR1-6509-1#sh queueing interface Gi1/8
Interface GigabitEthernet1/8 queueing strategy:  Weighted Round-Robin
  Default COS is 0
       01         WRR                 08
       02         WRR                 08
       03         WRR                 08
       04         Priority            01
     1     1      0 1 2 3 4 5 6 7
     1     2
     1     3
     1     4
     1     5
     1     6
     1     7
     1     8
     2     1
     2     2
     2     3
     2     4
     2     5
     2     6
     2     7
     2     8
     3     1
     3     2
     3     3
     3     4
     3     5
     3     6
     3     7
     3     8
     4     1
        01         WRR                 08
     1     1      0 1 2 3 4 5 6 7
     1     2
     1     3
     1     4
     1     5
     1     6
     1     7
     1     8
     2                0  []
     3                0  []
     4                0  []
KB-SR1-6509-1#
Hello Zeeshan,
The numbers you are looking are different one is the output the other is input queue.
You have highlighted it transmit queue in QoS output and input queue on interface.
So both seems right.
You may find more information about the queue in the following link:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bf98.shtml#queue_drops
The following document is about input and output queue on the interfaces:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml
HTH,
Alex
*Please rate helpful posts
Hi Alexander,
Many Thanks for the update
Pls find Below  output from Queuing command
sh queuing interface Gi1/6  (pls find relevant info below from the command)
    2                0  []
    3                0  []
    4                0  []
Below is output from sh int Gi1/6  (pls find relevant info below from command)
Pls find my  question below
When we see packet drop on queue 1 999434248 (packets droped on transmit)  shouldnt we see the total output drops go up with the sh int command.  (both input drops and output drops are zero with the Sh interface command)
We are looking forward for an network upgrade and I am trying to do an audit and am bit confused here  (trying to identify bottle necks so we can purchase the right cards etc) accroding to the sh int command there is no congestion / drops according to the Queuing command they are drops.  (WE have QOS disabled so all traffc is in queue 1)
Kind Regards,
Zee
Hello Zee,
Maybe the easiest approach will be opening a case with TAC because configuration should be checked, the version of the software also, some capture or debugs maybe needed.
Just to ask you one more thing are these counters increasing?
Best regards,
Alex
HI Zeeshan,
Is this input drops getting increase very min or during any specific point of time? Is there any way to configure the SPAN on this port to see what burst of traffic is hitting this interface? You can once clear the counters on this interface and monitor the situation and see what specific time the drops gets increased?
Inayath
Hi Alexander / Sharieff,
Many thanks for your reply much appreciated
I have checked the stats and the drops using the sh queuing int Gi1/6 and have not gone up I will keep an eye if they go up will run a span sessionss and log a call with TAC
MAny Thanks for your help
Zee
