Switching and Routing Problem Fix
magdalen143
Switching and Routing Problem Fix Most importantly, one should be concerned with personal safety. Be certain to date a person several times online prior to exchanging information like phone numbers or before setting up a plan to meet. When one does set up a meeting plan, arrange to meet the person in a public place, preferably in broad daylight. If there is anything about the prospective date that makes you uncomfortable, don't hesitate to cancel or rearrange.  Just as in face-to-face dating, honesty is important. Internet dating etiquette suggests being truthful about what one looks like, actual interests, and actual age. Don’t post a picture that is twenty years old, where you are fifty pounds lighter. As well, don’t express interest in things that really are not interesting. For example, if one meets a hang-glider enthusiast but one is afraid of heights, don’t fake an interest in an activity in which one would never take part.
InayathUlla Sharieff
Hi Magdalen,
What exactly you are trying to tell here?
This is a technical forum not sure what you are looking for?
Inayath
chr6is000
ahhh so this is like an analogy for the network you have. your love life is non-existent and unreliable, like UDP very unreliable while you are looking for a relationship in a public place in day like and that represents TCP. this routing protocal is based on the hangliding that is switched(with a 2950) back and forth from your emotional insecurities
easy fix, you must have a screw loose(in your router) just go get a hammer and hammer is back it
did this technical advice help solve your problem.
please click correct answer at the bottom, thanks
CM
