09-12-2025 09:08 AM
C9500 and C9300 running 17.12.5
I have a working port-channel between the 2 switches with 1 active interface.
When i add and enable a second interface the channel goes down and shortly after up, but then i have extremly high packet loss and loose management connection to the "other" switch.
Below is my config. I have looked at "sh interfaces counters errors" and "sh interfaces transceiver detail" and there is no errors or high values on the fiber sfp ports.
The log does not show anyting except the interface goes up and down, when i enable/disable it.
The interface which causes this is twe1/0/30 on SW1 and twe1/1/4 on SW2.
Any good ideas?
SW1
interface Port-channel33
switchport mode trunk
interface TwentyFiveGigE1/0/30
channel-group 33 mode active
interface TwentyFiveGigE2/0/5
SW2
description UPLINKS
storm-control broadcast level 10.00 5.00
storm-control multicast level 10.00 5.00
ip dhcp snooping trust
interface TwentyFiveGigE1/1/1
channel-group 3 mode active
interface TwentyFiveGigE1/1/4
*Sep 12 17:20:41.174: %LINK-5-UPDOWN: Interface TwentyFiveGigE1/0/30, changed state to up
*Sep 12 17:20:45.284: %LINEPROTO-5-UPDOWN: Line protocol on Interface TwentyFiveGigE1/0/30, changed state to up
*Sep 12 17:21:06.634: %LINK-5-CHANGED: Interface TwentyFiveGigE1/0/30, changed state to administratively down
*Sep 12 17:21:07.634: %LINEPROTO-5-UPDOWN: Line protocol on Interface TwentyFiveGigE1/0/30, changed state to down
096427: Sep 12 15:23:37.459: %LINK-3-UPDOWN: Interface TwentyFiveGigE1/1/4, changed state to up
096428: Sep 12 15:23:41.523: %LINEPROTO-5-UPDOWN: Line protocol on Interface TwentyFiveGigE1/1/4, changed state to up
096429: Sep 12 15:24:01.921: %LINEPROTO-5-UPDOWN: Line protocol on Interface TwentyFiveGigE1/1/4, changed state to down
096430: Sep 12 15:24:02.927: %LINK-3-UPDOWN: Interface TwentyFiveGigE1/1/4, changed state to down
Robert
Solved! Go to Solution.
09-13-2025 03:36 AM
i would suggest some tips here for best practice.
1. Always only allow required VLAN in the port-channel to make it work as expected (both the side), make sure spanning tree will be configured where you need root bridge for VLAN.
2. if this is trusted port avoid using storm-control - this may trigger different issue.
3. what is cause of interface go down, you can see error disable reason.
4. Do all the configuration global configuration before you make the port-channel enable(before hand) - later you can add any interface to port-channel is easy and no other side effects take place.
on PO 3 you see lot of input errors :
268115 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
09-17-2025 12:21 AM
I ended up replacing the fiber patch cable on port twe1/0/30 and now it works.
09-12-2025 09:49 AM
- @robert Any reason for the different port channel numbers on the switches ( 3 versus 33) ?
Use show etherchannel summary and show lacp neighbor on both switches.
Confirm that both interfaces are bundling correctly and that LACP sees the same system ID and port-channel.
The storm control configuration is also asymmetric (SW1 does not have it) ; for starters I would remove it on both
and try again,
M.
09-13-2025 01:35 AM
Channel group 33 neighbors
LACP port Admin Oper Port Port
Port Flags Priority Dev ID Age key Key Number State
Twe1/0/30 SP 32768 20db.ea50.9d80 493s 0x0 0x3 0x135 0x34
Twe2/0/5 SA 32768 20db.ea50.9d80 18s 0x0 0x3 0x132 0x3D
Number of channel-groups in use: 38
Number of aggregators: 38
Group Port-channel Protocol Ports
10 Po10(SU) LACP Twe1/0/19(P) Twe2/0/44(P)
11 Po11(SU) LACP Twe1/0/1(P) Twe2/0/26(P)
12 Po12(SU) LACP Twe1/0/2(P) Twe2/0/25(P)
13 Po13(SU) LACP Twe1/0/26(D) Twe2/0/1(P)
14 Po14(SU) LACP Twe1/0/25(D) Twe2/0/2(P)
15 Po15(SD) -
21 Po21(SU) LACP Twe1/0/3(P) Twe2/0/28(P)
22 Po22(SU) LACP Twe1/0/4(D) Twe2/0/27(P)
23 Po23(SU) LACP Twe1/0/28(D) Twe2/0/3(P)
24 Po24(SU) LACP Twe1/0/27(s) Twe2/0/4(P)
30 Po30(SD) -
31 Po31(SU) LACP Twe1/0/5(P) Twe2/0/30(P)
32 Po32(SU) LACP Twe1/0/6(P) Twe2/0/29(P)
33 Po33(SU) LACP Twe1/0/30(D) Twe2/0/5(P)
34 Po34(SU) LACP Twe1/0/29(P) Twe2/0/6(P)
35 Po35(SU) LACP Twe1/0/15(D) Twe2/0/40(P)
41 Po41(SD) LACP Twe1/0/7(D) Twe2/0/32(D)
42 Po42(SD) LACP Twe1/0/8(D) Twe2/0/31(D)
43 Po43(SD) LACP Twe1/0/32(D) Twe2/0/7(D)
44 Po44(SD) LACP Twe1/0/31(D) Twe2/0/8(D)
51 Po51(SU) LACP Twe1/0/9(P) Twe2/0/34(P)
52 Po52(SU) LACP Twe1/0/10(D) Twe2/0/33(P)
53 Po53(SU) LACP Twe1/0/34(P) Twe2/0/9(P)
54 Po54(SD) LACP Twe1/0/33(D) Twe2/0/10(D)
61 Po61(SU) LACP Twe1/0/11(P) Twe2/0/36(P)
62 Po62(SU) LACP Twe1/0/12(P) Twe2/0/35(s)
63 Po63(SU) LACP Twe1/0/36(D) Twe2/0/11(P)
64 Po64(SD) LACP Twe1/0/35(D) Twe2/0/12(D)
71 Po71(SU) LACP Twe1/0/13(P) Twe2/0/38(P)
72 Po72(SU) LACP Twe1/0/14(P) Twe2/0/37(P)
73 Po73(SD) LACP Twe1/0/38(D) Twe2/0/13(D)
74 Po74(SD) LACP Twe1/0/37(D) Twe2/0/14(D)
90 Po90(SU) LACP Twe1/0/23(P) Twe2/0/24(P)
91 Po91(SD) -
100 Po100(SU) LACP Twe1/0/47(P) Twe2/0/47(P)
109 Po109(SD) LACP Twe1/0/46(D)
110 Po110(SU) LACP Twe1/0/45(P)
111 Po111(SU) LACP Twe2/0/45(P)
Channel group 3 neighbors
Twe1/1/1 SA 32768 20db.ea9f.6fa0 19s 0x0 0x21 0x506 0x3D
Twe1/1/4 SP 32768 20db.ea9f.6fa0 562s 0x0 0x21 0x31F 0x34
Number of channel-groups in use: 2
Number of aggregators: 2
1 Po1(SD) -
3 Po3(SU) LACP Twe1/1/1(P) Twe1/1/4(D)
09-12-2025 10:36 AM
I think I would try to configure UDLD to see if it triggers on this.
Can you post the output of show interface from both sides as well?
09-13-2025 01:39 AM
sh int po3
Port-channel3 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 20db.ea50.9db1 (bia 20db.ea50.9db1)
Description: UPLINKS
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 10Gb/s, link type is auto, media type is N/A
input flow-control is on, output flow-control is unsupported
Members in this channel: Twe1/1/1
Last input 00:00:00, output 00:13:56, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 292000 bits/sec, 337 packets/sec
5 minute output rate 311000 bits/sec, 365 packets/sec
368504895 packets input, 93195908455 bytes, 0 no buffer
Received 159862045 broadcasts (22051891 multicasts)
0 watchdog, 22051891 multicast, 0 pause input
153140059 packets output, 26328392741 bytes, 0 underruns
Output 6920806 broadcasts (379064 multicasts)
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
#sh interfaces po33
Port-channel33 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 20db.ea9f.6fa5 (bia 20db.ea9f.6fa5)
Description: ** H3.X3 **
Members in this channel: Twe2/0/5
Last input 00:16:41, output 00:00:00, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 170
5 minute input rate 316000 bits/sec, 355 packets/sec
5 minute output rate 295000 bits/sec, 339 packets/sec
86761569 packets input, 13958034425 bytes, 0 no buffer
Received 450629 broadcasts (143607 multicasts)
0 watchdog, 143607 multicast, 0 pause input
133551500 packets output, 27050732408 bytes, 0 underruns
Output 33798102 broadcasts (6969784 multicasts)
0 output errors, 0 collisions, 3 interface resets
09-13-2025 01:49 AM
enable udld on the int two1/0/30 and twe2/0/5 on Po33 did not show any uni links when i have the twe1/0/30 interface enabled.
Total number of bidirectional entries displayed: 2
TH-DK-MID2-DIST-01#sh udld neighbors
Port Device Name Device ID Port ID Neighbor State
Twe1/0/30 20DBEA509D80 1 Twe1/1/4 Bidirectional
Twe2/0/5 20DBEA509D80 1 Twe1/1/1 Bidirectional
09-12-2025 11:19 AM
Normal' stp detect loop and down link before lacp add new port to PO
What you need is only shut/no shut PO
And all will be OK.
MHM
09-13-2025 01:37 AM
Did a shut on Po33, enabled twe1/0/30 and did a no shut on Po33.
Same problem, extreme packet loss.
09-13-2025 01:46 AM
debug lacp [event|packet|fsm|misc]
debug condition <condition>
Run above debug
Note:- use conditions to only include interface (port member not port channel) have issue
Share debug here
Note:- run debug in both SW
MHM
09-13-2025 03:36 AM
09-17-2025 12:21 AM
09-17-2025 12:26 AM
Change fiber meaning there was uni directional' but your udld show bidirectional.
What meaning of uni' one side send lacp other not receive or not send lacp.
Anyway glad issue solved
MHM
09-17-2025 05:27 AM
this infact give you clue that cable gone wrong.
09-17-2025 09:31 AM
Thank you
