Packet Tracer - How to assign a VLAN to 2800 router port
marianodaniel
Hello! I'm doing some tasks on PT. I found one where I have a 2800 Router and I'm trying to assign a VLAN to Fa0/1 but cannot seem to find the command to do so.
Router#show running-config:
Spoiler
Building configuration...
Current configuration : 779 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip dhcp pool Pool1
default-router 10.0.0.1
no ip cef
no ipv6 cef
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/0
ip address dhcp
duplex auto
speed auto
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address dhcp
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Vlan1
ip address 10.0.0.1 255.255.255.0
interface Vlan2
mac-address 000d.bd38.4b01
router rip
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
interface Fa0/1 is a layer 3 interface (as evidenced by the 'no ip address' configuration under that interface. You can only assign Vlans to layer 2 interfaces (or to subinterfaces, as you already did in your example)...
M02@rt37
Hello @marianodaniel
Cisco 2811 router have got L3 interfaces. You can assign IP addresses but no vlan as you want to do.
Best regards
Joseph W. Doherty
As like a VLAN access port?
If so, may not be possible on a 2800 native routed port.
Of course, routed ports often support subinterfaces, which allows a router to work with a switch trunk port.
ISRs might also support bridge ports, allowing a BVI (believe later IOSs changed terminology).
Again, not sure you can mix a SVI with a routed port.
Possible option, use an Ethernet module.
@marianodaniel hi, fa 0/0 and fa0/0 are routed ports. you cannot convert them to switch ports. but if you add module like HWIC-4ESW, you can configure VLAN on those new ports.
Good luck
KB
