Packet Tracer LAB(VTP)
i am working on Packet Tracer on VTP.. But it is not working properly.. VTP client was not receiving the VLAN updates from server switch...  please tell me any one facing the same problem on packet tracer.. Sample simple config below for two swithces..
SWITCH 1
sh vtp status
VTP Version                     : 2
Configuration Revision          : 1
Maximum VLANs supported locally : 255
Number of existing VLANs        : 6
VTP Operating Mode              : Server
VTP Domain Name                 : CCNP
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0x69 0xEA 0x7A 0x35 0x7A 0xD8 0x1D 0xD5
Configuration last modified by 0.0.0.0 at 3-1-93 00:01:23
Local updater ID is 0.0.0.0 (no valid interface found)
sh vlan brief
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/2, Fa0/3, Fa0/4
                                                Fa0/5, Fa0/6, Fa0/7, Fa0/8
                                                Fa0/9, Fa0/10, Fa0/11, Fa0/12
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/16
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24
                                                Gig1/1, Gig1/2
10   VLAN0010                         active
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
Switch 2
h vtp status
VTP Version                     : 2
Configuration Revision          : 0
Number of existing VLANs        : 5
VTP Operating Mode              : Client
MD5 digest                      : 0x1B 0xA3 0x02 0x27 0xF9 0x0D 0x27 0xF1
Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
sh vlan brief
                                                Gig1/1, Gig1/2
You must use trunk ports in order to get VTP going.
interface fa0/1
swithport mode trunk
end
It could be that after you configure these trunk ports, no vtp updates are getting through. Create a dummy vlan on the VTP master switch to see if it works.
vlan 999
name dummy-vlan
exit
6 Replies 6
Reza Sharifi
Can you post the config for the interface connecting the 2 switches together?
Also, are you using the same VTP password for both switches?
can you post sh run and sh ip int bri from both switches?
Switch 1
SW1#sh running-config
Building configuration...
Current configuration : 1034 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname SW1
spanning-tree mode pvst
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
SW1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
SW1(config)#int
SW1(config)#interface f0/1
SW1(config-if)#no sh
SW1(config-if)#no shutdown
SW1(config-if)#
SW1(config-if)#
SW1(config-if)#
SW1(config-if)#
SW1(config-if)#
SW1(config-if)#^Z
SW1#
%SYS-5-CONFIG_I: Configured from console by console
SW1#
SW1#sh run
version 12.2
hostname SW1
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch 2
sh run
SW2#sh running-config
version 12.2
hostname SW2
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
both are connected interface fa0/1
SW1#sh interfaces fa0/1
FastEthernet0/1 is up, line protocol is up (connected)
  Hardware is Lance, address is 0002.1765.8601 (bia 0002.1765.8601)
BW 100000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
  input flow-control is off, output flow-control is off
  Last input 00:00:08, output 00:00:05, output hang never
  Queueing strategy: fifo
  Output queue :0/40 (size/max)
     956 packets input, 193351 bytes, 0 no buffer
     Received 956 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 watchdog, 0 multicast, 0 pause input
     2357 packets output, 263570 bytes, 0 underruns
     0 output errors, 0 collisions, 10 interface resets
     0 lost carrier, 0 no carrier
SW2#sh interfaces fa0/1
  Hardware is Lance, address is 0090.0c69.3301 (bia 0090.0c69.3301)
I am not using VTP passwords..
SW1#sh ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/1        unassigned      YES manual up                    up
SW2#sh ip interface brief
interface fa0/1
end
vlan 999
name dummy-vlan
exit
ya thank you.. I forgot to do that.... its working now..
So, do we need to make trunk ports on all the switches. that is on server and on clients both?
Thanks in advance.
I took a detour during a VTP lab and learned to make sure to do a NO VTP PASSWORD command on the clients and server.....I learned even when you change the Domain name the password sticks.  Also changed all trunking ports to DYNAMIC DESIRABLE
Hope this helps someone.
