Packets not NATED and go directly via routing
MaximBudyonny
Hi!
Wery simple configuration but it doesn't work.
I've configured router 2811 to NAT packets from different hosts that arrive from interface fa 0/0.200 (subinterface for VLAN200) via static NAT
Packets arrive from fa 0/0.200 but NAT doesn't create entries for some of them.
This packets go directly by routing. I can see this packets in OUT access-list binded to the outbound interface
I think that the root of the issue is missconfiguration but couldn't find it.
Here is part of my config
---------------Static NAT---------------
ip nat inside source static tcp 10.0.32.93 3000 10.251.1.29 3000 extendable
ip nat inside source static tcp 10.0.32.94 3000 10.251.1.30 3000 extendable
ip nat inside source static tcp 10.0.32.125 3000 10.251.1.31 3000 extendable
------------------INBOUND INETRFACE-----------------
interface FastEthernet0/0.200
description TO-LOT-OF-INTERNAL-HOSTS-THAT-MUST-BE-NATED
encapsulation dot1Q 200
ip address 172.22.0.101 255.255.255.252
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1200
ip ospf message-digest-key 200 md5 7 XXX
ip ospf network non-broadcast
no snmp trap link-status
no cdp enable
end
---------------OUTBOUND INETRFACE---------------
interface Vlan3
description OUTSIDE-NATED-PACKETS-MUST-ENCRYPT-AND-GO-TO-REMOTE DESTINATION
ip address X.X.X.Z 255.255.255.252
ip nat outside
crypto map TO-REMOTE
end
---------------ROUTING---------------
ip route 10.1.15.0 255.255.255.0 IPADDR 240 tag 333 name REMOTE-DEST
mahmoodmkl
Level 7
Level 7
And the address u have defined in u r NAT statements are different than configured on ur f0/0.200 interface.Can u tell us why u have used the address different then the source of NAT.
Mahmood
