Parser view gives permission to commands incorrectly
savamoti
Hi community,
IOS Version 15.2(4)E7
I am trying to use parser view to restrict some commands for user.
For example: allow user only two actions - create vlan and name it
Parser-view configured like this:
parser view senior
 secret 5 $1$UgXf$K/RFpnFQPntcfI0gA8p.K1
 commands configure include all vlan
 commands exec include configure terminal
 commands exec include all show
all—A "wildcard" that allows every command in a specified configuration mode that begins with the same keyword or every subinterface for a specified interface to be part of the view.
I can create vlan, but can't name it:
switch>show privilege
Currently in View Context with view 'senior'
switch>?
Exec commands:
  <1-99>     Session number to resume
  configure  Enter configuration mode
  enable     Turn on privileged commands
  exit       Exit from the EXEC
  show       Show running system information
switch>configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
switch(config)>vlan 99 switch(config-vlan)>? VLAN configuration commands: exit Apply changes, bump revision number, and exit mode switch(config-vlan)>name test ^ % Invalid input detected at '^' marker.
What am I doing wrong?
balaji.bandi
not sure what device is this, you need enable and do config t to get that work.
>enable
#config t
BB
Please, read my post properly.
I don't need to enable, i'm already in view:
conf t is there, i'm able to create vlan, but can't name it
Device: cisco WS-C4900M
