Partial adjacency in Nexus 7k OTV
bonestorm
Hi all,
I've been troubleshooting an issue with Nexus 7010 dealing with site adjaceny.  I have four 7ks (two at each site).  Site1-N7K1 is linked via DWDM to Site2-N7K1 over a layer 3 link (the join interface) and this forms an adjaceny.  The same happens with Site1-N7K2 and Site2-N7K2.
However I can't get a full adjacency from the N7Ks in the same site over a layer 2 link, even though the site VLAN is definitely up.  This is the output from 'sho otv site':
Site1-N7K1# sho otv site
Local Edge Device Information:
    Hostname Site1-N7K1
    System-ID 4055.3906.99c1
    Site-Identifier 0000.0000.0001
    Site-VLAN 789 State is Up
Site Information for Overlay1:
Local device is AED-Capable
Neighbor Edge Devices in Site: 1
Hostname                 System-ID        Adjacency-       Adjacency-   AED-
                                          State            Uptime       Capable
(null)                   64a0.e740.8741   Partial           2d21h        Yes
Does anyone have any ideas on what could be causing this?  When I do a 'show ip mroute' I only see an entry for the L3 join interface, I'm not sure if this is the problem.
Mark
stevenmcnamara
What does "show otv site detail" say?
Do you have a dedicated OTV VDC? I'm guessing from your description you are have dedicated point to point DWDM services. See this:
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/DCI/whitepaper/DCI_1.html#wp1186215
The use of OTV VDCs is also required in point-to-point deployments where a pair of separate physical devices is deployed in a dedicated DCI layer to perform the OTV functionality.
stevenmcnamara
Thanks Steven,
You are absolutely correct with this answer.  I pointed the join interface at our existing network core rather than through the point to point DWDM and the adjacencies came up no problem.
Mark
DOUG GODING
I am also having a similar issue with the partial adjacency, however my OTV extension is working.
It seems that the Site VLAN communication is not working correclty, however I have verified the L2 path between the two Nexus switches. I get the same as below from either switch.
Switch2-otv(config)# sh otv site
Dual Adjacency State Description
    Full     - Both site and overlay adjacency up
    Partial  - Either site/overlay adjacency down
    Down     - Both adjacencies are down (Neighbor is down/unreachable)
          - Site-ID mismatch detected
    Hostname Switch2-otv
    System-ID 04c5.a4e8.cec4
    Site-Identifier 0001.0001.0001
    Site-VLAN 3919 State is Up
Site Information for Overlay0:
Switch 1-otv           4055.3920.4b44   Partial           00:00:10     Yes
___________________________________________________________________________________________
Switch1-otv# sh otv vl
OTV Extended VLANs and Edge Device State Information (* - AED)
VLAN   Auth. Edge Device                     Vlan State       Overlay
  10   Switch2-otv                        inactive(Non AED)Overlay0
  19*  Switch1-otv                        active           Overlay0
Switch2# sh otv vlan
  10*  Switch2-otv                        active           Overlay0
  19   Switch1-otv                        inactive(Non AED)Overlay0
