password recovery on 3750g switch
hi
can anybody help me in password recovery for a 3750g switch
regards
gopi
smothuku
Level 7
Level 7
Hi Gopi ,
Please check the below link which helps you to reset the password of 3750 switch.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.1_19_ea1/configuration/guide/swtrbl.html#wpxref25330
Cheers :)
satish
I thought this could help: I followed the procedure outlined in Cisco doc. It didn't work for me. I have a 3750 48PS switch.
What worked is the following:
- hold the mode button pressed while you plug the power cord,
- wait, while the mode button is still pressed, for about 5 sec,
- release the mode button and quickly press it again until you see the following menu:
The system has been interrupted prior to initializing the
flash filesystem.  The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
    flash_init
    boot
switch:
