Password reset not working on Catalyst 9410
kuhn_colby
I messed up configuring a switch and put Radius on without setting up a local account. I can't log in since it wants a username and password that doesn't exist. I've tried following the password recovery instructions and can get to ROMMON but after I put in the switch_ignore_startup_cfg=1 command and try boot from packages.conf it fails. It just loads my messed up config. Any ideas?
Seb Rupik
Hi there,
Last time I checked the rommon commands are case sensitive, try:
SWITCH_IGNORE_STARTUP_CFG=1
cheers,
Seb.
That's what I was doing wrong. I didn't realize it was case sensitive. Thanks for the help.
balaji.bandi
Follow below guide to ignore the config :
https://community.cisco.com/t5/networking-documents/catalyst-9400-password-recovery/ta-p/3913437
still have issue (post complete logs to understand what is wrong ?)
The Cisco Standard procedure to recover the passwords, below document help you.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/software/release/16-6/configuration_guide/sys_mgmt/b_166_sys_mgmt_9400_cg/b_166_sys_mgmt_9400_cg_chapter_01100.html#task_nzq_q4z_n1b
BB
