PBR question.
Hi Guys,
I would like to ask how could I define a PBR if the VLAN is behind ASA? There is no SVI set in 6509. I can't set ip policy route-map command on Gig2/6.
6509:
ip access-list extended ACL-ATT-TO-RIVERBED
 permit ip 10.199.24.0 0.0.0.255 10.226.147.163 0.0.0.0
 permit ip 10.199.26.0 0.0.0.255 10.226.147.163 0.0.0.0
route-map RM-TO-RIVERBED permit 10
 match ip address ACL-ATT-TO-RIVERBED
 set ip next-hop 10.199.195.253
interface GigabitEthernet2/6
 description ASA003_TRUNK_1_P
 switchport
 switchport mode trunk
 load-interval 30
 speed 1000
 duplex full
 wrr-queue bandwidth 20 100 200
 priority-queue queue-limit 5
 wrr-queue queue-limit 65 15 15
 wrr-queue random-detect min-threshold 1 70 100 100 100 100 100 100 100
 wrr-queue random-detect min-threshold 2 70 100 100 100 100 100 100 100
 wrr-queue random-detect min-threshold 3 40 40 50 50 60 60 70 70
 wrr-queue random-detect max-threshold 1 100 100 100 100 100 100 100 100
 wrr-queue random-detect max-threshold 2 100 100 100 100 100 100 100 100
 wrr-queue random-detect max-threshold 3 70 70 80 80 90 90 100 100
 wrr-queue cos-map 2 1 1 2
 wrr-queue cos-map 3 5 3 4
 wrr-queue cos-map 3 7 6 7
 rcv-queue threshold 1 50 50 60 60 100 100 100 100
 rcv-queue threshold 2 60 80 100 100 100 100 100 100
 rcv-queue cos-map 1 1 0
 rcv-queue cos-map 1 2 1
 rcv-queue cos-map 1 3 2
 rcv-queue cos-map 1 4 3
 rcv-queue cos-map 2 1 4
 rcv-queue cos-map 2 2 5
 rcv-queue cos-map 2 3 6
 rcv-queue cos-map 2 4 7
 mls qos trust dscp
 auto qos voip trust
 spanning-tree portfast edge trunk
end
ASA:
ASA003# show run int GigabitEthernet0/1.24
interface GigabitEthernet0/1.24
 vlan 24
 nameif att
 security-level 100
 ip address 10.199.24.1 255.255.255.0 standby 10.199.24.2
ASA003# show run int GigabitEthernet0/1.26
interface GigabitEthernet0/1.26
 vlan 26
 nameif att_ii
 security-level 100
 ip address 10.199.26.1 255.255.255.0 standby 10.199.26.2
Jackie
Reza Sharifi
Hi Jackie,
If you are running version 9 or later on your ASA, it supports PBR.
see link:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa90/configuration/guide/asa_90_cli_config/ha_cluster.html#pgfId-1943033
