PBR route map problem
nhksocgen1
Community Member
Hi guys,
I got a problem with a route map.Traffic enters from interface gi0/1 with source 10.10.0.0/14. I am trying to ping google DNS
interface GigabitEthernet0/1
ip address x.x.x.1 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip policy route-map modems
duplex auto
speed auto
no mop enabled
route-map modems permit 10
match ip address 101
set ip next-hop y.y.0.245
access-list 101 permit ip 10.10.0.0 0.3.255.255 any log
I got the following debug output which shows me that policy is not matched:
000170: Dec 19 22:03:00.563 PCTime: IP: s=10.10.11.234 (GigabitEthernet0/1), d=8.8.8.8, len 60, FIB policy rejected(no match) - normal forwarding
Any help will be highly appreciated.
Thanks!
9 Replies 9
Reza Sharifi
From the PBR doc:
When the destination route exists in the routing table, normal       forwarding is used—do not policy route the packet.
R1# debug ip policy Policy routing debugging is on*Dec 4 12:50:57.363: IP: s=100.100.100.3 (Ethernet0/0), d=200.200.200.4, len 100, policy match*Dec 4 12:50:57.363: IP: route map blah, item 10, permit*Dec 4 12:50:57.363: IP: s=100.100.100.3 (Ethernet0/0), d=200.200.200.4 (Serial2/0), len 100, policy rejected -- normal forwarding
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a00801f3b54.shtml
I got static default route - do you think this is the problem?
If you have a default route than try using the first scenario in the link I provide and test again.
Tryed it doesn't work
Just want to add that the next hop is on the other side of a tunnel..but it doesn't matter since the route map doesn't match on gi0/1
Remove the log keyword in the ACL.
Regards.
Alain
Julio Carvajal
Hello Nikolay,
Is interface gig 0/1 the first interface that packet gets in? or is that the outside???
Also from where are you pinging?? A computer or the router itself?
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hi firends,
thanks for you vaulable proposals. The problem was the ACL -for some reason it doesn't match the traffic, even I can swear in it
Anyway...what I did was instead :
match interface gi0/1
So every packet entering that interface is subject to PBR.
And it worked!
Thanks once again and have a bautiful Christmas!
If your issue is resolved, please select correct answer and to make thread resolved for community. It might help for somebody else.
Abzal
Best regards,
Abzal
