pbr to remote gateway failing
dedra_live
Hello
I have configured pbr on 2821. And the next hop on route map is pointing another subnet and not same as the router interface to which route map is applied. should this type of configuration work. ios version is 12.4
I dont see anything on debug ip policy
thanks
cadet alain
the next-hop must be directly connected otherwise it won't work.
Regards.
Alain
Thanks.
The network setup is two routers (on different networks) are directly connected to the same firewall. The return path/route for the source WAN subnet defined on the FWSM is pointing to router B. However, for some destination networks I would like to make FWSM point to router A for the same source WAN subnet. Since FWSM does not support PBR, I have configured PBR on router B. So that when such a traffic reaches router B, the route-map should get trigged and it points to router A (which is on different/directly connected network).
If I were to point it FWSM, it would route back to router B again.
Please suggest.
Thanks.
could you post a topology diagram because I don't see exactly the design and goal you wish to achieve.
Regards.
Alain
