PBR with VLAN interface
lveraza2010
Community Member
I have configured step by step PBR on my core switch.  The core switch is using 2 L3 VLAN and it has connected 2 routers. Every VLAN has to use one router like default gateway, but If one router fails, all the traffic will be sending to the active router.
The problem that I have is that PBR is not working, when I put on VLAN interface ´ ip policy route-map NAME ´, the core switch doesn’t accept this command, it does nothing.
Do you have any idea why not?.
Thank you, best regards, Luis.
2 Accepted Solutions
Hi Luis,
Take a look at the following configuration guide for the 3560 below, it details the steps for configuring PBR including configuring the SDM template.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3560/software/release/12.2_50_se/configuration/guide/swiprout.html#wp1228588
To use PBR, you must first enable the routing  template by using the sdm prefer routing global  configuration command.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3560/software/release/12.2_50_se/configuration/guide/swsdm.html#wpxref88774
Allan.
Hope this helps, pls rate helpful posts.
Luis
Follow Allan's instructions about the sdm routing template and you should be fine.
Jon
Please also rate helpful posts
14 Replies 14
Jon Marshall
Luis
What switch, which IOS and which feature set (for IOS and feature set just post a "sh version").
Jon
Here the info:
ROUTERNAME#sho ver
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(40)SE, R
ELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 24-Aug-07 01:39 by myl
Image text-base: 0x00003000, data-base: 0x01800000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWA
RE (fc1)
ARBUESWTADM01 uptime is 12 weeks, 4 days, 17 hours, 26 minutes
System restarted at 19:49:45 HAA Thu Jan 21 2010
System image file is "flash:c3560-ipservicesk9-mz.122-40.SE.bin"
Thank you.
Have you enabled the sdm routing template ?
Jon
No, I didn´t have any idea about sdm routing template, Do i need ?, for what is it ?. Thank you.
Hi Luis,
Allan.
Luis
Jon
Hi, based on Cisco document I have enabled sdm prefer dual-ipv4-and-ipv6 routing with PBR.
´´ The software supports IPv4 PBR only when the dual-ipv4-and-ipv6 routing template is configured´´
The show sdm prefer command is showing next:
ROUTER#sh sdm prefer
The current template is "desktop IPv4 and IPv6 routing" template.
The problem that I have yet, the IP policy route-map NAME is not working, I enable it but the switch does nothing.
Do you have another idea why is not working ?.
PBR is not working, as yo know, If I can´t enable IP policy route-map, PBR won´t work.
´´ Enables policy routing and identifies a route map to be used for policy routing ´´.
Thank you, best regards. Luis Veraza.
Luis
Can you post the config together with the test details you carried out that didn't work.
Jon
Here the config:
ROUTER#show conf
Using 8169 out of 524288 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service sequence-numbers
hostname ROUTER
enable password
no aaa new-model
clock timezone HAA -3
system mtu routing 1500
track 123 rtr 1 reachability
track 124 rtr 2 reachability
ip subnet-zero
ip routing
ip sla 1
icmp-echo 192.68.84.251
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 192.68.84.252
ip sla schedule 2 life forever start-time now
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2  1
mls qos srr-queue input cos-map queue 1 threshold 3  0
mls qos srr-queue input cos-map queue 2 threshold 1  2
mls qos srr-queue input cos-map queue 2 threshold 2  4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3  3 5
mls qos srr-queue input dscp-map queue 1 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3  0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3  32
mls qos srr-queue input dscp-map queue 2 threshold 1  16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2  33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2  49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2  57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3  5
mls qos srr-queue output cos-map queue 2 threshold 3  3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3  2 4
mls qos srr-queue output cos-map queue 4 threshold 2  1
mls qos srr-queue output cos-map queue 4 threshold 3  0
mls qos srr-queue output dscp-map queue 1 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3  48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3  56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3  16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3  32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1  8
mls qos srr-queue output dscp-map queue 4 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3  0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan dot1q tag native
interface GigabitEthernet0/1
interface GigabitEthernet0/28
interface Vlan1
ip address 192.68.81.254 255.255.252.0
interface Vlan3
ip address 192.68.84.253 255.255.255.248
interface Vlan93
ip address 192.68.93.254 255.255.255.0
ip helper-address 192.168.81.4
ip classless
ip route 0.0.0.0 0.0.0.0 192.68.84.251
ip route 0.0.0.0 0.0.0.0 192.68.84.252
ip http server
ip http secure-server
access-list 100 permit ip 192.68.80.0 0.0.3.255 any
access-list 101 permit ip 192.68.93.0 0.0.0.255 any
route-map BAD permit 10
match ip address 100
set ip next-hop verify-availability 192.68.84.251 10 track 123
set ip next-hop verify-availability 192.68.84.252 20 track 124
route-map BAV permit 10
match ip address 101
set ip next-hop verify-availability 192.68.84.252 10 track 124
set ip next-hop verify-availability 192.68.84.251 20 track 123
line con 0
password
line vty 0 4
password
login
length 0
line vty 5 15
password
login
ntp clock-period 36028795
end
ROUTER#
And when you say it isn't working how are you proving that ?
Jon
I typed next:
ROUTER#show ip policy
Interface Route map
ROUTER#
It showed me nothing, later I reviewed the current config and the Interface VLAN1 is showing only the IP address.
Thanks, best regards, Luis.
Luis
Have you tried applying the route-map to the vlan interface or even after setting up the SDM template are you saying it is still not applying ie.
vlan
ip policy route-map
Also note from your config you don't need 2 route-map names ie. you can just do -
route-map BAD permit 20
Jon
You´re right.
I changed these route-map numbers some days ago, they don´t have the same number now, BUT ! I removed them and I added again some minutes ago and the IP policy is working.
Thanks a lot, it´s working now.
Best regards, Luis.
lveraza2010 wrote:
You´re right.
Best regards, Luis.
Luis
Glad you got it working.
Jon
