Bookmark
Subscribe
842
Per-VLAN Policy Map QoS and mls qos trust dscp--Catalyst 2960XRs
tom.neteng
I am working on a switch configuration and it would appear that the previous engineer made a mistake on the opposite sides of the trunk ports for the core and access switches' Etherchannel member ports, or else I am simply not familiar with QoS sufficiently enough to properly interpret the old configuration.  Would someone please be able to clarify these examples:
There is a policy-map defined for QoS and applied at the VLAN level.
Etherchannel is currently setup between switches and will be on the new ones, as well.
Core side of trunk on switchports:
mls qos vlan-based
Access switch side of trunk on switchports:
mls qos trust dscp
Do both sides need to be defined with both for this to function properly?  Is it even necessary to explicitly trust dscp on an Etherchannel member port or regular trunk port?
I would be greatly appreciative of any corrections or improvements on this configuration.
Here is an approximation of the old config:
Core
interface Port-channel1
switchport mode trunk
interface Gig1/0/1
description *** Etherchannel Member to Stack 1 ***
srr-queue bandwidth share 1 60 10 29
srr-queue bandwidth shape 16 0 0 0
priority-queue out
mls qos vlan-based
channel-group 1 mode active
Access
interface GigabitEthernet1/0/1
description *** Etherchannel Member to Core ***
priority-queue out
mls qos trust dscp
And the new:
Core
interface TenGigabitEthernet1/0/1
priority-queue out
mls qos trust dscp
mls qos vlan-based
Access
priority-queue out
mls qos trust dscp
mls qos vlan-based
Hello
My understanding ...:
srr-queue bandwidth share 1 60 10 29 Share the bw  on % of the value specified
srr-queue bandwidth shape 16 0 0 0  -
Overrides share mode, so in this case queue 1 in share mode is render ineffective , but the remaining 3 queues will be shared based on their value %
So the above reads
Shape 16 queue 1 =  1/16th of the interface ( 100mb link that's 6mb)
Shared queue 2/3/4 = 74mb remaining  ratio: 6:1:3 ( if my maths are correct)
priority-queue out - This is a priority queue and then renders both the shape and shared values ineffective plus it will eat up as much BW as it desires and will stave the other queues
mls qos trust dscp <
trust dscp traffic
mls qos vlan-based
< -  Enables vlan QOS on the trunks carrying the vlans with service policy's applied to the SVi of that vlan
res
Paul
Kind Regards
Paul
