Periodic Slow Response 2821 (300+ms, 1 minute)
ironman
This could be LAN or WAN I believe...
My solarwinds NPM reports very slow response times from my satellite clinic.
Often times it is 300ms to 600ms when it should be 10-15ms.
CPU does not seems to spike, the memmory does not seem to spike
The bandwidth does not spike.
It happens mostly during work hours about 10 times a day
Solarwinds reports the delay and then 2 minutes later it reports normal activity
I have broadcast/multicast control on the switches
We have static route for our network meaning no routing protocols
We have 12 other clinics with the same configs and they are fine
I have double checked the configs but I am not holding my breath on that item
I have rebooted the router without affect
I have not replaced the cable to the demarc on either side of the WAN connection
I have not reseated the service provider T1 cards
I have not reseated the T1 card on either router
Any thoughts?
All the best and thank you in advance,
Bill Branch
North Country HealthCare
Director of Information Technology
O: 928.774.8254
C: 928.607.9746
Shelley Bhalla
Level 3
Level 3
Review Interface counters. if there is a serial link - review the controllers as well for any errors/clocking issues.
Please do a standard ping test with 1500 byte size packets on the wan link. How long does the incident last? If there is a 1-2 minute time period, During the issue this ping test will help narrow down the issue.
Shelley.
Cisco TAC.
