07-12-2019 03:34 AM
Hi All,
I am trying to connect "ASR 1002" port G0/*/* to "switch 9300" port Te1/*/* but the link is not coming up, fiber connection.
Hardware details :
Using SFP = > GLC-SX-MMD ( ASR port ) and using SFP => SFP-10G-SR ( switch port ).
Fiber cable - LC
Please let me know if I am using wrong SFP or cable to connect the devices.
KM
Solved! Go to Solution.
07-12-2019 03:42 AM
07-12-2019 03:54 AM
Yes both the side same SFP model, if the distance below MMD specification.
07-12-2019 04:16 AM
07-12-2019 03:42 AM
07-12-2019 03:50 AM
Thanks for your reply !!
So I should use both end GLC-SX-MMD ?
07-12-2019 03:54 AM
07-12-2019 04:03 AM
No, it is not working.
Still the port is down.
KM
07-12-2019 04:16 AM
07-12-2019 04:24 AM
Perfect , thanks for your response much appreciated !! it worked.
Best Regards
KM
07-12-2019 04:30 AM
07-12-2019 04:39 AM
Cheers and glad all working as expected.
