Ping problem
jimmyzeng
Community Member
I have ping problem and can not figure out.
I have 4 switches, 2x 3550,2x2950. They are connected with each with 2 cables.
They all have a  intel vlan 1
S1 172.16.1.3
S2 172.16.1.4
S3 172.16.1.103
S4 172.16.1.104
I can ping all in any switch.
I can ping 172.16.1.3 4 104 from windows CMD.
But no 103.
All switch have no routing protocol, only vlan 1.
I was using wireshark.
I can see the right mac address from ARP reply.
But no ICMP reply.
I don't understand why?
Please help me? Any idea? Advice?
jimmyzeng
Community Member
Screen shot of wireshark
pradeepser
Level 3
Level 3
Can you please ensure that S3 configured with ip default gateway command?
Pradeep
is your network looks like this, that two 2950 are connected to each other and then each 2950 to 3550 as per the below diagram?
2950<=====>2950
3550<=====>3550
ashirkar
Level 5
Level 5
Hello Jimmy,
What subnet mask you are using on switch.Check subnet mask on all switches.
Ashish
