pinging problem
arakesh12345
Community Member
  R1
   SW
   pc1
am getting pinging problem  repetedly
what is the problem
above my topology
C:\Users\indeo>ping 111.93.219.41
Pinging 111.93.219.41 with 32 bytes of data:
Request timed out.
Request timed out.
Reply from 111.93.219.41: bytes=32 time=5ms TTL=254
Request timed out.
Ping statistics for 111.93.219.41:
Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
Approximate round trip times in milli-seconds:
Minimum = 5ms, Maximum = 5ms, Average = 5ms
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
Request timed out.
Request timed out.
Request timed out.
Julio E. Moisa
It could be a faulty cable, interface or NIC (layer 1). Also it could be generated by a high CPU on a device.
Is possible to know the configuration on the ports (Router/Switch/PC), is the problem associated to this host only?
Thank you.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
ho am know it is by cpu utilization
am attached the doc
use show cpu history to see if the cpu spiked around the time of the ping loss
