PIX processor load high.
KlediBodinaku24
I have a 515E PIX. Sometimes the processor load gets very high. I have noticed that the process who is using the processor is IP Address Assign process. I have about 25 users who log in with Cisco VPN Client to which it has been assigned a pool of IP's and from that pool i have assigned a static IP to each user.
When the process load gets high the PIX does not allow the other users to log in.
When i Disable and than enable the Use of internal address pools everything goes to normality.
Can someone help me.
sourabhagarwal
Level 4
Level 4
check the number of concurrent sessions estabalsihed in PIX using "show connection" command. This will tell you if any specific IP is initiating many sessions and on which TCP/UDP port.
