%PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding on 2960XR Switches? what
Willem de Groot
Hi all,
my customer has a lot of WS-C2960XR-24PS-I  (15.0(2)EX4) 24 and 48 Port switches, some are in a stacks, others not. All have 2 Powersupplies.(each 640 Watt)
Now he notice this message every 5 minutes, but not on all switches.
Looking at the switch, the PS seems to be ok.
There is a known issue, but this one only mention the problem during insertion, not during normal runningtime.
What can be the problem here?
Willem
Additional Information:
CustomerSwitch#
Nov 27 09:28:44.622 CEST: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
CustomerSwitch#
Nov 27 09:33:44.642 CEST: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
CustomerSwitch#
CustomerSwitch#
CustomerSwitch#sh env all
FAN PS-1 is OK
FAN PS-2 is OK
SYSTEM TEMPERATURE is OK
System Temperature Value: 41 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 67 Degree Celsius
Red Threshold : 75 Degree Celsius
POWER SUPPLY 1A TEMPERATURE: OK
POWER SUPPLY 1B TEMPERATURE: OK
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A PWR-C2-640WAC DCB1728B1K2 OK Good Good 250/390
1B PWR-C2-640WAC DCB1738B2A1 OK Good Good 250/390
CustomerSwitch#
--- ende -------
Release Notes for Catalyst 2960-X and 2960-XR Series Switches, Cisco IOS Release 15.0(2)EX5
---SNIP---
  • CSCuh65397
During the insertion or removal of a power supply, the following message might be displayed on the console:
There is no functional impact. There is no workaround.
---SNIP---
Hi ,
As per the Bug note, (see the Further Problem Description:)
Workaround:
NA
If this log is repeated even after OIR, It should be different issue. It has to be debugged separately
VS.Suresh
This is way over a year old.. and still exists today in ios flash:/c2960x-universalk9-mz.152-2.E3.bin
I have instances where the logs are filling up with bs..
Carlos Villagran
Hi!
This is a cosmetic bug, please refer to the following link for detailed explanation of the bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuj33250/?referring_site=bugquickviewredir
Upgrading to release 15.2(2) will fix the issue.
Hope it helps, best regards!
JC
