Please help me in configuring a Cisco 2800 series router!
raghavbhardwaj
Hi! I have to configure a new router with a static route. No routing protocol will be used. I just have to set default route on it and NAT. My senior Network Engineer has asked me to configure this router. There's an apartment where our Overseas employees stay, earlier this apartment had a broadband connection which was further divided through the APs(Cisco Wireless Access Points) and made usable to around 20 users. Now, they have bought in their own lease line and I have to configure this router. We just have to connect it with the ISP using Ethernet (not serial link). I would be so so grateful if you can just type in complete configuration for this. Thanks a ton in advance!
Zach Smith
This is going to take some more question/answer but this will get you started.
Your ISP for the new circuit should provide you with the IP information for the router.  For example sake lets assume you are given 1.2.3.5 255.255.255.252 as your IP information.  They also give you 1.2.3.6 as the gateway for your router.  And assuming your LAN network is 10.10.10.0/24.  And I think the 2800's are fast Ethernet and not gig..can't remember.  So this part may be different.
config t
clock timezone EST -5 0
clock summer-time EDT recurring
service password-encryption
service timestamps debug datetime localtime show-timezone msec
service timestamps log datetime localtime show-timezone msec
username me priv 15 password 0 mypassword
enable secret 0 somepassword
interface fa0/0
 ip address 1.2.3.5 255.255.255.252
 no shut
 no ip redirects
 no ip unreachables
 ip nat outside
interface fa0/1
 ip address 10.10.10.1 255.255.255.0
 no shut
 no ip redirects
 no ip unreachables
 ip nat inside
access-list 100 remark **Internal NAT Pool**
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
ip nat inside source list 100 interface fast 0/0 overload
ip route 0.0.0.0 0.0.0.0 1.2.3.6
banner login ^
##Authorized access only.  Unauthorized access is prohibited.  Contact 555-555-5555 for help.##^
line con0
logging synchronous
password 0 somepassword
ntp server yourdomaincontrollerIP
Just a little caveat to the above.  This is VERY basic config.  I'd need to know more about your objectives to get something better.  This will get your started though with basic connectivity.
is your router running DHCP?  If so you may want to add this as well.
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool 10-LAN
 network 10.10.10.0/24
 default-router 10.10.10.1
 domain-name yourdomain.local
 dns-server yourdomaincontrollerIP
Hi There,
Thanks for your great help!
Below is the final template which my NE provided me:
Now I have to configure this router and then further need to connect various workstations with the same network. Please let me know what needs to be done further.
Thanks!
Configuration:::
ip domain-name CVT.net
logging buffered 128000 informational
logging console errors
logging monitor notifications
no aaa new-model
clock timezone IST 5 30
ip cef
no ip domain lookup
username aptadmin secret
enable secret
crypto key generate rsa
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
service dhcp
ip dhcp pool LAN-POOL
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 4.2.2.2
domain-name CVT.net
lease 1
interface FastEthernet0/0
 description *********Spectranet WAN*********
 ip address x.x.x.x 255.255.255.252
 load-interval 30
 duplex full
 speed 100
 ntp disable
 no cdp enable
interface FastEthernet0/1
 description Connect to LAN
 ip address 192.168.1.0 255.255.255.0
 no ip redirects
 duplex auto
 speed auto
 ntp disable
ip forward-protocol nd
no ip http server
no ip https server
control-plane
banner exec $
                  Network Provided by CVT
This system is restricted to authorized individuals. Unauthorized access is a
criminal violation of the law and is subject to prosecution. Please disconnect
if you are not an authorized individual. Otherwise, you will be prosecuted
to the full extent of State and Federal law.
All connections and changes are logged.
************** Warning - Warning - Warning **************
banner login $
Authorized Associates only! Please disconnect your connection if
you are not an authorized Associate. Otherwise, you will be
prosecuted to the full extent of State and Federal law.
line con 0
 exec-timeout 15 0
 password 7
 login local
line aux 0
 exec-timeout 15 0
 password 7 C@pt
 login local
line vty 0 4
 access-class 50 in
 exec-timeout 5 0
 login local
 transport preferred ssh
 transport input ssh
line vty 5 15
 access-class 50 in
 exec-timeout 5 0
 login local
 transport input ssh
end
