Please Help!
sr2470182
I want to replace a BT Internet modem with a cisco 2811 ADSL ISR.
Please what information do I need to get from BT to successfully configure the ADSL router.
6 Replies 6
John Blakley
Well, generally your provider will provide you with either a static address or assigned address. You'll need to contact your provider to see if it's a PPPoE account (uses username and password to get logged in). After that, you would configure your dialer interface, assign it to your public interface on your 2811, and that should be it. I'm assuming that BT is your internet provider?
John
HTH, John *** Please rate all useful posts ***
Cheers John,
I can see on the BT (internet) modem that it's a PPPoA, 0/38. Also I have that username & password to get logged in.
BT also gave me a range of (5) static IP Address for my network:
81.x.x.x. to 81.x.x.y
with a Gateway 81.x.x.z and subnet mask 255.255.255.248
However what I am not sure of is if I should configure my Dialer interface with IP Address DHCP or static.
Also do I need to configure interface BVI1.....Sorry, I am a bit confused.
Take a look at this document. It should give you step-by-step instructions on how to configure your router:
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a67e.shtml
HTH,
John
*please rate if helpful*
Dear,
Could you please tell me if the user/password that you have are to log to the router or the PPPoE connection ? that's not the same thing.
The IP address may be attributed to you by DHCP, to see make the IP address as negotiated (to be DHCP) on the Dialer interface.
Is it OK ? or need more information ??
Omar
Hi Omar,
The user/password are to login to the PPPoE connnection.
Law
Have you did any configuration ? if yes, please send it to me.
If not, here is a sample of PPPoE :
bba-group pppoe global
interface FastEthernet0/0
description CONNECTED TO ADSL CONNECTION
no ip address
duplex half
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no shut
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname
ppp chap password
ip route 0.0.0.0 0.0.0.0 Dialer1
Please try this a give a feedback.
Rate if that help.
Omar
