Please help!
cmishra
Community Member
Cisco 9300 switch
SW version- 16.12.4
%SFF8472-3-THRESHOLD_VIOLATION: Te2/1/5: Rx power low warning; Operating value: -9.9 dBm, Threshold value: -9.9 dBm.
7 Replies 7
Leo Laohoo
Post the complete output to the following command:
sh interface Te2/1/5
sh interface Te2/1/5 transceiver detail
Clean the optics and clean the patch cable.
I've seen many messages of this type when the SFP is non Cisco.
Regards, LG
*** Please Rate All Helpful Responses ***
Hi Liviu,
All SFPs are Cisco and it's alert are showing last few days.
Without any type of network activity in the  whole network.
balaji.bandi
Is this Interface up and working ?
check the Physical cables and also how is the environment temperature ?
Try replacing the SFP with another SFP and test it
Still issue try upgrade to latest code 17.6.X onwards and check.
BB
Hello @cmishra ,
the Optical Receive Power of interface Te2/1/5 is -9.8 dBm and the warning threshold of the interface is set at -9.9 dBm. It's not the end of the world as the interface counters are clean.
Do you have a similar interface with the same SFP and a similar FO cable run? Can you look at and share the show interface Te... transceiver detail of that interface for comparison?
Regards, LG
