11-03-2008 08:07 AM - edited 03-06-2019 02:16 AM
hello
my customer got this error message time to time even if channel is configured under lacp instead pagp ??
where can i dig into , (configuration are ok on both side and error free on coutners)
12.2.18SXF4
any comments appreciated
JYP
Solved! Go to Solution.
11-03-2008 08:20 AM
I am suspecting the link to be flapping here. Can you configure "logging event link-status" under the interfaces?
Also, try following config commands and see if the problem persists ?
1) errdis recovery cause pagp-flap
2) errdis flap cause pagp max 10 time 30
11-03-2008 08:20 AM
11-03-2008 08:37 AM
hello
thanks for your reply
is it safe that you asked to do since
customer is in production ?
let me know
JYP
11-03-2008 08:45 AM
logging event link-status commands
is it supported in 12.2.18 ?
i looked on descriptions and see only on
12.2(25)SG
JYP
11-03-2008 01:02 PM
It is supported and an interface configuration. You can enable the command with no impact
11-04-2008 04:17 AM
thanks guy !
patch panel connector was defective on one port
JYP
