Switch 2950 boot problem
m.belateche
Community Member
The switch boots up immediately into Rommon mode. The flash system is empty. Is there a way to copy a new ios into the flash file system?
Thanks for any pointer
Jon Marshall
You will need to use xmodem to transfer a new IOS onto the 2950. Attached is a link to recovering software on 2950 switches -
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_20_ea2/configuration/guide/swtrbl.html#wp1021167
Make sure you set BAUD rate to 115200 as that will speed things up a bit 🙂
Jon
