POE controller on 3560
Matt McFarlane
Frequent Visitor
Frequent Visitor
I have a remote 3560X switch which has produced the following error messages. Nothing is connected to port 22, none of the other devices require POE from the switch. Port 21 came back online, but not 23 or 24. Any ideas what this refers to and whether it can be corrected remotely or needs to be replaced.
Nov 25 08:21:06: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/21: Power Controller reports power supply VEE under voltage and lockout
Nov 25 08:21:06: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/22: Power Controller reports power supply VEE under voltage and lockout
Nov 25 08:21:06: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/23: Power Controller reports power supply VEE under voltage and lockout
Nov 25 08:21:06: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/24: Power Controller reports power supply VEE under voltage and lockout
Nov 25 08:21:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/24, changed state to down
Nov 25 08:21:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/23, changed state to down
Nov 25 08:21:08: %LINK-3-UPDOWN: Interface GigabitEthernet0/24, changed state to down
Nov 25 08:21:08: %LINK-3-UPDOWN: Interface GigabitEthernet0/23, changed state to down
Nov 25 08:21:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/21, changed state to down
Nov 25 08:21:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/21, changed state to up
lmediavilla
Level 6
Level 6
Usually ports are controlled 4 by 4, so if there is a hardware failure of something that controlls one port 4 will go away, thats why 21, 22, 23 and 24 have problems with PoE
Kind regards
Leo Laohoo
I have never seen an error message like this before.
1.  What is the IOS version you are using?
2.  Have you tried erasing the configuration of both ports and determine if the error message returns?
3.  Post the output to the command "sh power inline".
4.  Have you tried to "shut/no shutdown" the port?
5.  Have you tried to reboot the switch?
lmediavilla
Level 6
Level 6
Kind regards
Thanks for your help. There was a hardware failure of the inline power controller which requires replacement of the switch to use those ports with POE.
swapsakker
Level 3
Level 3
I had upgraded to c3560cx-universalk9-tar.152-6.E2, so with a downgrade it helped.
