Bookmark
Subscribe
1255
PoE switch uplink behaviour
Ge Qu
We have an uplink port went down and up itself this morning. The switch is WS-C3560-48PS-S and ios is 12.2(55)SE10. The port went down and then up is one port of the port channel. when I check the logs, i got the following:
097615: Feb  8 2018 08:40:42.068 EST: %ILPOWER-7-DETECT: Interface Fa0/48: Power Device detected: IEEE PD
097616: Feb  8 2018 08:40:42.160 EST: %ILPOWER-5-POWER_GRANTED: Interface Fa0/48: Power granted
097617: Feb  8 2018 08:40:42.521 EST: %ILPOWER-5-IEEE_DISCONNECT: Interface Fa0/48: PD removed
097618: Feb  8 2018 08:40:43.175 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/48, changed state to down
097619: Feb  8 2018 08:40:43.309 EST: %ILPOWER-7-DETECT: Interface Fa0/48: Power Device detected: IEEE PD
097620: Feb  8 2018 08:40:43.401 EST: %ILPOWER-5-POWER_GRANTED: Interface Fa0/48: Power granted
097621: Feb  8 2018 08:40:43.770 EST: %ILPOWER-5-IEEE_DISCONNECT: Interface Fa0/48: PD removed
097622: Feb  8 2018 08:40:44.181 EST: %LINK-3-UPDOWN: Interface FastEthernet0/48, changed state to down
097623: Feb  8 2018 09:22:42.089 EST: %ILPOWER-7-DETECT: Interface Fa0/48: Power Device detected: IEEE PD
097624: Feb  8 2018 09:22:42.181 EST: %ILPOWER-5-POWER_GRANTED: Interface Fa0/48: Power granted
097625: Feb  8 2018 09:22:42.542 EST: %ILPOWER-5-IEEE_DISCONNECT: Interface Fa0/48: PD removed
097626: Feb  8 2018 09:33:14.326 EST: %ILPOWER-7-DETECT: Interface Fa0/48: Power Device detected: IEEE PD
097627: Feb  8 2018 09:33:14.418 EST: %ILPOWER-5-POWER_GRANTED: Interface Fa0/48: Power granted
097628: Feb  8 2018 09:33:14.795 EST: %ILPOWER-5-IEEE_DISCONNECT: Interface Fa0/48: PD removed
097630: Feb  8 2018 09:45:20.154 EST: %LINK-3-UPDOWN: Interface FastEthernet0/48, changed state to up
097631: Feb  8 2018 09:45:22.168 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/48, changed state to up
Is this normal in a PoE switch? can someone tell me why it's happening?
if it's not normal, what i can do for trouble shooting?
Thank you.
Reza Sharifi
No, this is not normal.  From the log message you posted, it appears that the switch is not giving power to the port when this happens. I would open a ticket with TAC and send them the logs for analysis.  They most likely will recommend an upgrade.  In the meantime, if you have a non-POE port open use that for your uplink.
Can I just disable the power on that port? Would it be good while I am
waiting for an upgrade?
Thank you
Yes, if you can apply it to the interface, it should work.
no power inline never
