port 80 inbound
carl_townshend
Hi all, we have a server here that needs to recieve information back on port 80, we have a one to many PAT setup on the firewall, if something needs to talk to this pc on port 80 directly does it need some kind of one to one nat, or a port forward setting up ?
5 Replies 5
royalblues
Level 10
Level 10
Hi Carl,
If i understand your question correctly, i think you want to access your server on port 80 from outside i.e internet.
For this you will have to do a static NAT for the server to a public IP and access the server over the public IP on port 80
eg..
Server internal IP : - 172.16.100.1
server external IP: - 200.200.200.200
nat(outside,inside) 172.16.100.1 200.200.200.200
access-list acl_in permit tcp any host 200.200.200.200 eq 80
HTH, rate if it does
Narayan
do i need another public address for this or can I use my one address I have and just port forward on port 80 to this server whilst still having internet access fro my other machines
Hi Carl
You are right.
The public ip address you would be using for this server should be different from the one you are using for PAT
Narayan
No I meant to say that the public address will be the same, but I have done this at home with 1 ip, used pat for my pc's internet connection and port forwarding for my web server, is this ok
Carl,
you would be required to use 2 ip address one for pat and one for the web server
Narayan
