seeking advice on vpnclient accessing lan server
bangkydotnet
Hi guys,
I would like to seek some advice on my network setup.
pc running vpnclient (10.0.1.2)
<internet>
(int e0/0 dynamic ip)
Cisco 2611 (NAT and VPN server)
(int e0/1 10.0.0.1/24)
<ethernet>
server (10.0.0.100/24)
with regards to the following setup, currently from my pc vpnclient, i cannot access my server though my vpn connection is setup succesfully.
could someone please enlighten me on how to troubleshoot this?.. thanks in advance.
below is the relevant parts of my config
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group MYGROUP
key VPNKEY
domain vpn.xxx.com
pool vpnpool
acl vpnpool
crypto ipsec transform-set ESP-3DES esp-3des esp-sha-hmac
crypto dynamic-map CRYPTO_MAP 1
set security-association lifetime seconds 86400
set transform-set ESP-3DES
reverse-route
crypto map CRYPTO_MAP client authentication list authenList
crypto map CRYPTO_MAP isakmp authorization list authorList
crypto map CRYPTO_MAP client configuration address respond
crypto map CRYPTO_MAP 20 ipsec-isakmp dynamic CRYPTO_MAP
interface Ethernet0/0
ip address dhcp
ip access-group OUTSIDEACL in
ip nat outside
ip inspect FW out
half-duplex
no cdp enable
interface Ethernet0/1
ip address 10.0.0.1 255.255.255.0
ip nat inside
full-duplex
no cdp enable
ip access-list extended OUTSIDEACL
deny icmp any any
permit tcp any any eq 22
permit tcp any any eq 25421
permit tcp any any eq 8022
permit tcp any any eq 9022
permit tcp any any eq 8080
permit udp any eq isakmp any eq isakmp
permit esp any any
deny tcp any any
permit udp any eq ntp any
permit udp any eq bootps any
deny udp any any
deny ip any any
ip access-list extended vpnpool
permit ip 10.0.1.0 0.0.0.255 10.0.0.0 0.0.0.255
permit ip 10.0.0.0 0.0.0.255 10.0.1.0 0.0.0.255
spremkumar
Level 9
Level 9
You have missed out to post the ip pool in the process and also you are trying to create ipsec tunnel with dynamic ips on both the sides which i feel is not a generic thing to do so..
regds
hi kumar, thanks for pointing that out.
here's the ip pool
ip local pool vpnpool 10.0.0.103 10.0.0.105
as for dynamic ips.. i think it should be alright cos the ip on my router changes very very infrequently (almost static)
