Port Channel and Routes question
tmatthews2
Hello:
I have two 6509's connected via port channel.  The switches are independent, so each set of routes and the VLAN database is unique to each switch.
Switch B has a route that sends traffic to a designated trunked port which access a separate network.  There is a server on Switch A that needs to send data to the trunked port on Switch B.
Is it as simple as creating a route on A that points to port on switch B?
Please find uploaded doc and let me know your comments
5 Replies 5
kolliparadeepak
how that data has been used in Switch B? If data to be accessed between two vlans, then allow that server on Switch A VLAN on that trunk and create a route (inter VLAN Routing on Switch B with the help of Router it is connected ) or if its used in same vlan that Server on Switch A, then allow that vlan on that trunk interface
The data on Switch B goes out a Port which has an L2 connection to a remote data center.  So the port has an IP assigned, 10.10.10.101  I have a route on switch B that says 10.20.20.0 255.255.255.0 10.10.10.101.  This creates the next hop and data can traverse the L2.
So should the route on Switch A say 10.30.30.0 255.255.255.0 10.10.10.101?
How is routing works in your environment (Using external Router or Using Switch Multilayer Capabilities)?
Is 10.10.10.101 default gateway address ? (I mean router ip address)
Are you able to ping 10.10.10.101 from switch A?
The switch does the L3.  I cannot ping the port on Switch B from Switch A.
I have static routes in the switches for traffic.  the IP's I gave were just examples.
