05-22-2014 05:22 PM - edited 03-07-2019 07:30 PM
hey guys, testing my network using IPSLA but its strange how when i connect a router to the network and input the IPSLA commands it says it fails everytime? Im a student doing my project btw and am unsure why its not sending through the network. I have connectivity and can ping across the entire network. the commands i used were -
ip sla monitor 12
type jitter dest-ipaddr
192.168.0.10 dest-port 5060
frequency 300
exit
ip sla monitor schedule 12 start-time now live forever
then when i use the statistics command to show the output it says failed :S am i missing a step somewhere, or do i have to advertise the router in my network? im very confused 😕
Solved! Go to Solution.
06-03-2014 07:19 PM
Could you include the config for the IP SLA receiver as well if you have it configured?
Excellent reading on the topic: http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipsla/configuration/15-mt/sla-15-mt-book/sla_udp_jitter.html
06-03-2014 07:19 PM
06-10-2014 04:34 PM
Thank you for your reply, i read up and have it all working now! The problem was in the Receiver not being able to connect past its gateway. Thanks again!
