port channel and sub interface
WILLIAM STEGMAN
Level 4
Level 4
I have a router on  which I would like to create a port channel that spans two different Nexus 2248TP switches, and then create a couple subinterfaces on the router's po interface.  I've done this successfully on my primary router, but the config doesn't seem to work on the backup router.  The primary is running IOS 15, while the backup is running 12.4.25d advanced IP.  I do see the trunk come up from the switch side, and my router subinterfaces and po interface show up, however I'm not able to get anywhere from the router.  It's not even able to reach other hosts on the same network.  As soon as I remove the port channel config and use the physical interface and assign the same address used on the port channel interface, everything works as expected and I have connectivity.
interface Port-channel21
no ip address
hold-queue 150 in
interface Port-channel21.248
encapsulation dot1Q 248 native
ip address 100.100.100.1 255.255.255.0
interface FastEthernet0/0
no ip address
duplex auto
speed auto
channel-group 21
interface FastEthernet0/1
no ip address
duplex auto
speed auto
channel-group 21
thank you,
Bill
have you tried removing native from the encapsulation dot1Q 248 native command? is the native vlan the same on both ends of the link and on all etherchannel trunks?
could you post the interface and portchannel interface configurations for both ends of the link please
Please remember to select a correct answer and rate helpful posts
Originally I set it up just using vlan 1 as the native vlan and only when that didn't work I tried using 248 as the native vlan.  So I've moved it back, same config that is working on my other router, to use vlan 1 as the native, but no change yet.
5548-1
interface Ethernet100/1/3
   description Public-Qwest-Secondary
   switchport mode trunk
   channel-group 21
interface port-channel21
   vpc 21
5548-2
   channel-group 21
   vpc 21
HBG-Nexus5k-2(config-if)# sh int trunk
Port          Native  Status        Port
               Vlan                  Channel
Eth1/1        1       trnk-bndl     Po1000
Eth1/2        1       trnk-bndl     Po1000
Eth1/3        1       trnk-bndl     Po1000
Eth1/4        1       trnk-bndl     Po1000
Eth1/8        99      trunking      --
Eth1/10       99      trunking      --
Po20          1       trunking      --
Po21          1       trunking      --
HBG-Nexus5k-1# sh int trunk
               Vlan                  Channel
Po20          1       trunking      --
Po21          1       trunking      --
Router side
no ip address
hold-queue 150 in
interface Port-channel21.1
encapsulation dot1Q 1 native
ip address 216.21.248.8 255.255.255.0
no ip address
duplex auto
speed auto
channel-group 21
no ip address
duplex auto
speed auto
channel-group 21
try hard-coding LACP on the switch ports.
If you do a debug arp on th switches and ping from the router to the switches, do you see the switches receiving the packet?
