06-20-2021 06:36 PM
I have a pair of c9300 switches with fibre between them. An aggregated interface using a port channel group is simple enough. However, Cisco offers a number of protocols for this - ISL, LACP, etc. What is the recommended choice?
06-20-2021 10:55 PM
Go with LACP , it's open standard.
## Make sure to mark post as helpful, If it resolved your issue. ##
06-21-2021 01:17 AM
Hello
LACP is non proprietary and can be used between other vendors however PAGP is Cisco’s own link control protocol and is used between cisco devices
06-21-2021 02:35 AM
Until you connecting OLD switch where is only ISL support, (Like brocade or other vendor)
LACP is good choice all time.
06-21-2021 06:30 PM
LACP or if it’s a routed port channel then you can do them as p2p.
