Port-channel between 9500 and 4500-x
k.aumell
- devices: C9500 (stackwise) and C4500 (VSS)
- trying to build port-channel but getting the following errors:
*Nov 9 15:40:04.795: %PM-4-ERR_DISABLE: channel-misconfig error detected on Te1/1/7, putting Te1/1/7 in err-disable state
*Nov 9 15:40:06.191: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/7, changed state to down
C9500 virtual stackwise
interface Port-channel126
description link to 4500x
switchport mode trunk
interface TenGigabitEthernet1/1/7
channel-group 126 mode active
interface TenGigabitEthernet1/1/8
interface TenGigabitEthernet2/1/7
interface TenGigabitEthernet2/1/8
4500-x VSS
interface Port-channel254
description Port-Channel to 9500-Distro
switchport
interface TenGigabitEthernet1/1/25
channel-group 254 mode active
interface TenGigabitEthernet1/1/26
interface TenGigabitEthernet2/1/25
interface TenGigabitEthernet2/1/26
Doesn't seem all that complicated. I do have Dual-active-detection link on 9500. 4500-x side does not go into error disable.
Its been days exchanging email with TAC, so any help is appreciated.
9500 show run attached
marce1000
 - Configure a syslog server (the same) on both devices , then configure logging trap debugging , try to make the link again , check the logs send to the syslog server.
 M.
