Stack 2 production 9200 switches with existing configuration
chong.eric
I have two catalyst 9200 switches which in production and i plan to stack them.   My question is if i just connect them with stack cables , what will happen to the switches?  Will all the existing configuration be wiped out?  Will them form the stacking? Both switches are running same version.
config will replace of second switch by first switch's configuration (which will select automatically or you can configure manually the switch number)
Good luck
KB
