Port Channel Configuration Between Nexus and IOS Switch
hogr fatih
Hello All
I am new to Nexus and I have issue here hope someone can help:
I have two switches in the network one of them is Cisco IOS C9500 which is a distrbution switch and the other side is cisco Nexus9000 C93240YC. I am trying to configure Port channel between and it shows all the time suspended both side and can't figure it out what is the issue.
 I appreciate if you can have any idea what is the issue.
On Nexus Switch:
interface port-channel78
description Distrbution-SW
switchport
switchport mode trunk
switchport trunk native vlan 888
switchport trunk allowed vlan 16,17,401
spanning-tree port type network
mtu 9000
speed 10000
On Cisco IOS:
interface Port-channel78
description Building2-SW
switchport nonegotiate
mtu 9000
21 Replies 21
balaji.bandi
is the Requirement to have only 1 Port in port-channel or nexus is vPC and you show online one switch site output ?
if only 1 port requirement why not use Trunk rather Port-channel (or you looking to add more ports later)
make sure you have all the VLAN Created both the side, including native VLAN
some time on nexus if only 1 port that will go disable - you can add no lacp suspend-individual
You sure see the Logs what is the reason it was suspended before
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_chapter_0110.html#...
BB
The reason I am having one port right now is beacuse the other port is trunk and running in production can't take it down. I want to bring the port channel up and then add the rest of the port.
all Vlans are created and already passing through trunk port
no lacp suspend-individual: already did this
It shows as suspended - what logs you see on both the devices ?
the message of your show it was down no operational members.
# show interface port-channel 78
port-channel78 is down (No operational members)
I also see some config not correct : one side you have speed setup another side switchport nonegotiate
can you post the output from both the devices : show run interface x/x and show interface x/x , show port-channel X show EtherChannel x summary
what mode of connectivity Ethernet or Fiber ? if Fibre ports used, what SFP and what Fibre used MM or SM ?
BB
On switch side :
show interfaces port-channel 78
Port-channel78 is down, line protocol is down (notconnect)
Hardware is EtherChannel, address is 0000.0000.0000 (bia 0000.0000.0000)
Description: na-us-709-skypark212-as01
MTU 9000 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, link type is auto, media type is N/A
input flow-control is on, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
Output 0 broadcasts (0 multicasts)
0 output errors, 0 collisions, 3 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
show interfaces twentyFiveGigE 2/0/20
TwentyFiveGigE2/0/20 is up, line protocol is down (suspended)
Hardware is Twenty Five Gigabit Ethernet, address is dc05.3989.ecb4 (bia dc05.3989.ecb4)
MTU 9000 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-LR
input flow-control is on, output flow-control is off
Last input 00:00:00, output 00:00:05, output hang never
394142 packets input, 36234608 bytes, 0 no buffer
Received 394142 broadcasts (394142 multicasts)
0 watchdog, 394142 multicast, 0 pause input
27860 packets output, 4067200 bytes, 0 underruns
Output 0 broadcasts (27860 multicasts)
0 output errors, 0 collisions, 8 interface resets
13955 unknown protocol drops
On Nexus :
admin state is up,
Hardware: Port-Channel, address: 4c5d.3cd3.dbec (bia 4c5d.3cd3.dbec)
Description: na-us-709-km2-ds01
MTU 9000 bytes, BW 10000000 Kbit , DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is trunk
auto-duplex, 10 Gb/s
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Switchport monitor is off
EtherType is 0x8100
Members in this channel: Eth1/45
0 interface resets
Load-Interval #1: 30 seconds
30 seconds input rate 16 bits/sec, 0 packets/sec
30 seconds output rate 792 bits/sec, 0 packets/sec
input rate 16 bps, 0 pps; output rate 792 bps, 0 pps
Load-Interval #2: 5 minute (300 seconds)
300 seconds input rate 72 bits/sec, 0 packets/sec
300 seconds output rate 568 bits/sec, 0 packets/sec
input rate 72 bps, 0 pps; output rate 568 bps, 0 pps
RX
0 unicast packets 27862 multicast packets 0 broadcast packets
27862 input packets 4067492 bytes
0 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 unicast packets 394188 multicast packets 0 broadcast packets
394188 output packets 36238908 bytes
0 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
show interface ethernet 1/45
Ethernet1/45 is up
admin state is up, Dedicated Interface
Hardware: 1000/10000/25000 Ethernet, address: 4c5d.3cd3.dbec (bia 4c5d.3cd3.dbec)
Port mode is trunk
full-duplex, 10 Gb/s, media type is 10G
Beacon is turned off
Auto-Negotiation is turned on FEC mode is Auto
Rate mode is dedicated
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
admin fec state is auto, oper fec state is off
Last link flapped 3d20h
Last clearing of "show interface" counters 4d20h
1 interface resets
30 seconds input rate 8 bits/sec, 0 packets/sec
30 seconds output rate 728 bits/sec, 0 packets/sec
input rate 8 bps, 0 pps; output rate 728 bps, 0 pps
RX
0 unicast packets 27864 multicast packets 0 broadcast packets
27864 input packets 4067784 bytes
0 Rx pause
TX
0 unicast packets 394215 multicast packets 0 broadcast packets
394215 output packets 36240991 bytes
0 jumbo packets
0 Tx pause
Fiber is used is SM and SFP both side are the same SFP-10GBase-LR
check the logs what is the reason suspended ?
one side it show as 10G-LR SFP- other side showing 10G only can you check that SFP again ?
BB
Here are th e output you requested Sir: I use Single Mode fiber cable and SFP both sides are SFP-10GBase-LR
ON NSK:
interface Ethernet1/45
switchport
switchport trunk allowed vlan 16,174,401
mtu 9000
speed 10000
channel-group 78 mode active
no shutdown
Ethernet1/45 is up
Port mode is trunk
EtherType is 0x8100
Last link flapped 5d21h
Last clearing of "show interface" counters 6d22h
1 interface resets
30 seconds input rate 72 bits/sec, 0 packets/sec
30 seconds output rate 760 bits/sec, 0 packets/sec
input rate 72 bps, 0 pps; output rate 760 bps, 0 pps
RX
0 unicast packets 39826 multicast packets 0 broadcast packets
39826 input packets 5814236 bytes
0 Rx pause
TX
0 unicast packets 600577 multicast packets 0 broadcast packets
600577 output packets 54468055 bytes
0 jumbo packets
0 Tx pause
admin state is up,
Description: na-us-ds01
Port mode is trunk
EtherType is 0x8100
0 interface resets
30 seconds output rate 768 bits/sec, 0 packets/sec
input rate 72 bps, 0 pps; output rate 768 bps, 0 pps
RX
0 unicast packets 39830 multicast packets 0 broadcast packets
39830 input packets 5814820 bytes
0 Rx pause
TX
0 unicast packets 600647 multicast packets 0 broadcast packets
600647 output packets 54474222 bytes
0 jumbo packets
0 Tx pause
show port-channel summary
Flags: D - Down P - Up in port-channel (members)
I - Individual H - Hot-standby (LACP only)
s - Suspended r - Module-removed
b - BFD Session Wait
S - Switched R - Routed
U - Up (port-channel)
p - Up in delay-lacp mode (member)
M - Not in use. Min-links not met
Group Port- Type Protocol Member Ports
Channel
78 Po78(SD) Eth LACP Eth1/45(I)
on the SW9500:
interface TwentyFiveGigE2/0/20
description na-us-709-NSK switch
mtu 9000
channel-protocol lacp
Description: na-us-NSK
Last input 00:00:00, output 00:00:09, output hang never
600773 packets input, 54485409 bytes, 0 no buffer
Received 600773 broadcasts (600773 multicasts)
0 watchdog, 600773 multicast, 0 pause input
39837 packets output, 5815842 bytes, 0 underruns
Output 0 broadcasts (39837 multicasts)
19942 unknown protocol drops
show etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 30
Number of aggregators: 30
Group Port-channel Protocol Ports
78 Po78(SD) LACP Twe2/0/20(s)
suggestion is :
create both side same VLANs  and make consistency config both the side :
shutdown the port-channel
make changes as below both :
no shutdown on the port-channel - check also check the logs what information it providing, when go suspended or go as (I) Individual
BB
