port-channel flapping when two more links are added!?
m-abooali
Level 4
Level 4
I have two Core 6509E SUP2T configued as VSS and has two 48 ports fiber blades. I have two 3750s, I have two gig on each 3750 port-channle to po1 and connected to both the core, one link to each core.
Now, I was asked ot add two more links on each 3750 switch to make it a total of 4 gigs on each 3750s (all 4 gig ports/uplinks will be in used an dtwo links to core one an dtwo links to core 2).
when i added two additional links on 3750s and bundled them to po1, I created another port channel on core and bundeled the additional two gigs on each core to accomodate for the two additional links (ports on core switches are not consequtives).
adding these two additional ports makes the 3750 switches flap between managemnet vlan and po1.
now, i am not sure if I must have added the two additional links on the core to teh current port-channel or core!? I have created another port-channel on core to accomodate for this currently!?
any thoughts on this is greatly appreciated.
Masood
2 Accepted Solutions
Ok Masood,
lets fix one 3750 switch first:
have a look at the config for po1 and the physical interfaces below
interface Port-channel1
switchport mode trunk
interface GigabitEthernet1/1/1
description description uplink to Core 6509 gi 1/1/24
shutdown
channel-group 1 mode passive
interface GigabitEthernet1/1/4
description description uplink to Core 6509 gi 2/1/24
shutdown
apply the same config on the 6500 but instead of passive use active see below
channel-group 1 mode active
make sure to shut the po1 first than apply the config and than bring up the po1
don't worry about shuting the physical interface
Reza
do you think I must use Gi1/1/22 and Gi1/1/22 or any available gig interfaces on the core fiber blade will do?
No, they don't have to be consecutive, they can be any interface from the module, but if you can keep it consecutive, it makes it easier to remember.
The only restirication is that you can not have links with different speed in a portchannel.
example
you can't have a portchannel with one 1Gig interface and one 10Gig interface.  All interfaces in a portchannel must have the same speed and duplex.
26 Replies 26
m-abooali
Level 4
Level 4
Correction!:
I did not create new port channel on teh core to accomodate new links but added two more ports to each link to the current port channel at teh core side.
On the 3750 on the other hand, I frist added two links to po1 so made it a taotal of 4 but it flaped so I created a different po for teh new two additional link but still flapped!?
Hope this is clear!?
Masood
Masood,
The additional links in all switches (VSS pair and the 3750s) need to be added to the existing portchannel (po1).  You don't need to create any new portchannel.  The best way to do it is to shut the portchannel first.
int po1
sh
than add the additional physical ports to the portchannel, and than bring up the portchannel.
int po1
no sh
This should bring up all the physical ports and the portchannel.
Thanks Reza. I have shut the port channels already.
I have Po1 on 3750 (two links on each switch to core)
on teh core, I had Po5 for Sw1 (3750) and Po6 for Sw2 (3750) and all was working fine until they wanted two more ports on each 3750 added!?
So, on teh core I added additional ports/connectionand added to PO5 and Po6 respectively. On the 3750s, i added two more links and added to Po1 but i noticed flapping.
So I shut po1 and a created a new Po2 on 3750s for the two additionbal links but still got flapping. So I have now, shut all port channles to see what I need to do next!?
Masood
by "for Sw1 and for Sw2, i mean on the core, I dded two more links to each current port-channles i.e. 5 and 6 whch was for connection to 3750 1 and 3750 2.
Sorry for the confusion if any!
Masood
Ok,
so you have, lets call it 3750-A that has 2 links and these 2 links are connected to the VSS pair (one to each switch) and  this is portchannel 5 right?
you also have a lets call it 3750-B that is also connected to the 6500 VSS via 2 connections and that is portchannel 6 right?
Are you using LACP or PAGP?
If this is the case please post the configs from the VSS pair and both 3750s?
Reza
Reza, you are right. the configuration listed aboive by you was working fine until I added two additional links to 3750s to each have a 4 gig bundle port-channel and for that I had to add two more links on each cores and boubdle them to po5 and po6.
3750-A and 3750-B bothe had Po1.
Core prime and Core stby as one VSs pair had PO5 and PO6.
I currently don;t have the configs with new links added but the config when all was working fine is here:
Also as for LACP and PAGP, I left all at default as the config shows.
CR2#sh run
Building configuration...
Current configuration : 4105 bytes
! Last configuration change at 02:43:41 UTC Mon Mar 1 1993
version 15.0
no service pad
hostname CR2
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750x-48p
system mtu routing 1500
no ip domain-lookup
vtp domain manh2usca
vtp mode transparent
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 50
interface Port-channel2
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
shutdown
channel-group 1 mode on
interface GigabitEthernet1/1/2
shutdown
interface GigabitEthernet1/1/3
shutdown
shutdown
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface Vlan1
no ip address
shutdown
interface Vlan50
description DATA_SW-MGMT
ip address 156.x.x.6 255.255.255.128
shutdown
ip http server
ip http secure-server
logging esm config
banner motd ^C
line con 0
privilege level 15
password cisco
login
transport output all
line vty 0 4
privilege level 15
password cisco
login
transport input telnet ssh
line vty 5 14
privilege level 15
password cisco
login
line vty 15
login
end
CR1:
Current configuration : 4258 bytes
! Last configuration change at 02:16:30 UTC Mon Mar 1 1993
version 15.0
no service pad
hostname CR1
boot-start-marker
boot-end-marker
no aaa new-model
ip routing
no ip address
no ip route-cache
description description uplink to Core 6509 gi 1/1/23
shutdown
description uplink to AT&T switch 02-CA02-NWYK-H-121-SW-01
shutdown
channel-group 2 mode on
description uplink to AT&T switch 02-CA02-NWYK-H-121-SW-02
shutdown
description description uplink to Core 6509 gi 2/1/23
shutdown
interface Vlan1
no ip address
interface Vlan50
ip address 156.x.x.5 255.255.255.128
shutdown
ip http server
logging esm config
banner motd ^C
line con 0
privilege level 15
password xxxx
login
line vty 0 4
privilege level 15
password xxxx
login
line vty 5 14
privilege level 15
password xxxx
login
line vty 15
login
end
hth
masood
Ok Masood,
shutdown
shutdown
Reza
Reza,
good Idea and if one works teh seocnd one must work too!?
what is the "passive" for on teh 3750s?
I will apply tomorrow and if that worked I will try the second switch.
on the core I have:
int Gi1/1/23 and Gi2/1/23 bounded to Po5
should I leave this as it except for the "active" command?
Please advise,
Masood
Massod,
With passive Command you are running LACP.  One side of the portchannel needs to be passive and one side needs to be active.  In this case the 3750 is passive and the 6500 is active.
Why are you using po5 on the 6500 and 1 on the 3750?  For simplicity, always use the same portchannel id on both sides of the connection
if the portchannel is 1 on the 3750 use 1 on the 6500.  If you are using 5 on the 6500 than use 5 on the 3750. (keep the numbers the same)
Not sure if I undestand the question
also, as I said before shut the po first do all the configs and than bring up the po.
no need to shut the physical interfaces.
Sure, since I have to use po5 on the core, i will use po5 on teh 3750s in new configuration.
Not sure if I undestand the question"
I meant, should leave the rest of the config on core the same but add "active" after port-channel 5 mode on?
Masood
no, you need to delete the channel-group command completely and add active (see below)
example
int gi1/1/1
no channel-group 1
Reza
shouldn't I add the additional interfaces in CR1?
that was the whole idea!?
it was working as it was without adding additional interfaces to po1 i.e. without adding
gi 1/1/2 and gi 1/1/3
So, I need to add the above interfaces and boundle to PO1 as it is a requirement.!?
Masood
Yes, add the additional interfaces
you can have up to 8 physical interface in a portchannel
on teh core, after I added new interfaces on teh 3750s, I need to create uplinks so should those uplinks be consequtibe?
I current have :
but when I add two more interfaces on 3750s, i need to add two more on the core too.
Thanks and sorry for all these emails.
Best Regads,
Masood
